New production run of Honda sohc 750 valves just completed.
These valves are real stainless steel and have hard chrome stems. APE is the only one that makes this valve, and it is available direct from APE, thru all APE distributors and all leading cylinder head shops.
APE developed these valves as an addition to our ever expanding real race valve line, when we became involved with the restoration of the R.C. Engineering iconic top fuel motorcycles, once ridden by the legendary Russ Collins. We found when doing the cylinder heads, that there were no valves available that you would want to run in a supercharged nitro Honda.
Now all Honda sohc 750 owners can benefit from this by the availability of a true high performance valve for every Honfa sohc 750.
They are available in std size, as well as 1.5mm oversize intake and 1 mm oversize exhaust. These valves racer at $24.95 each. Why settle for anything less in your engine.
http://cbrzone.com/sohc.html
