Author Topic: Ether to find air leaks  (Read 1307 times)
Offline eigenvector
« on: September 04, 2015, 07:16:27 PM »
Is ether safe to use when locating air leaks?  I ask because while carb cleaner works, it also saturates your bike with flammable fluid - the kind that later drips onto the exhaust pipes, engine case, etc..  One of the benefits ether brings is that it evaporates without a residue.  It sure likes to burn though :o.  So much so that I wonder if it's a little too flammable when working around a hot engine.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Bodi
Re: Ether to find air leaks
« Reply #1 on: September 04, 2015, 07:38:47 PM »
Ether is not safe around any source of ignition.
It's heavier than air and pools on the ground.
Explosive range is 3-27% in air.
An old science demonstration was to set a lit candle at one end of a table and a tissue soaked in ether at the other. In a few seconds a fireball flashes from the candle to the tissue.
I would use "quick start" ether spray to test for air leaks, I suppose. Outside. But the stuff is so volatile I think it would tend to get sucked into the air intake and lift revs even if there wasn't an air leak?
A quick start can makes a pretty sweet flamethrower.
Offline eigenvector
« Reply #2 on: September 04, 2015, 08:03:52 PM »
It's one of the reasons why I use carb cleaner to check for them currently.  It's just that carb cleaner is messy, and there are some formulations that don't burn.  The stuff I have will, but just barely.
I was wondering if just straight up compressed air would work - the kind that comes in a can?
Edit:  I should actually clarify here - I say 'ether' but what I'm really talking about is starting fluid - the kind that comes in a spray can.  I associate the two with each other but I recognize that they aren't the same thing.  Sorry if I confused you.
« Last Edit: September 04, 2015, 08:10:45 PM by eigenvector »
Rob
1977 CB550K
1983 VF750S Sabre
DH
« Reply #3 on: September 04, 2015, 08:20:39 PM »
Sometimes, if you use lots of it, water in an old windex pump-spray bottle will work.
Offline Jore
« Reply #4 on: September 04, 2015, 10:24:53 PM »
I've seen people use those disposable propane torches to locate air leaks on carbs, plus side of it is that since it's a gas you have no cleanup to do after.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #5 on: September 04, 2015, 10:42:37 PM »
I have never actually had any of these substances diagnose a vacuum leak whether there is one or not...if your boots are hard and cracked and/or you are using shoddy clamps, and your schidt don't run right, just send the bread to replace 'em
« Reply #6 on: September 04, 2015, 11:31:12 PM »
Starter Spray! It contains ether.
It was a must before in older cars. I had a car thet got it carburetor frozen around winter time. It must been the pilot cicruit when I could hold the engine going if keeping the revs up.
If it stopped, starter spray  was mandatory to make it start again.
