Hey guys. So on tuesday I got the new engine back up and running for the first time. It started right up and ran on the first crank. Initially it didn't run the best and hunted around and wouldn't settle into an idle. I went to time the ignition and noticed the timing was jumping around badly. You could see the advancer trying to advance at 1000 rpm. I remedied this by trueing the advancer shaft as it was out by 0.012" i got it to 0.003" and i also installed a tighter advancer. After this i was able to time the ignition and get good stable idle base timing out of it.
The carbs are the linked roundtops but are odd "064A" versions. They started out in very good condition and got fully cleaned ,rebuilt, floats adjusted, and bench sync'd. After getting the ignition setup i vacuum sync'd the carbs (bench sync was pretty close) and started playing with the air screws. I tried them anywhere from full closed to 2 turns open and didn't see any real difference in the running condition still hunting around and running a little funky.
Currently the pilots are #40 genuine Keihin originals the needles are in the 4th position from the top and currently #128 mains which will be re-assessed after i ride it for the first time tomorrow. But Im just wondering if I should be considering a change to #38 or #42 pilots? It doesn't seem like people generally need to change the pilots? The engine details are as follows
-Ebay cruzin image 836cc 65mm kit
-Lightly ported and de-shrouded head
-F2 cam
-Hindle 4-2-1 exhaust
-Original unmodified airbox (will be opening up the openings)
