Author Topic: 74 CB350F Carb Question  (Read 909 times)
Offline GizmoDuck
« on: September 19, 2015, 07:10:08 AM »
In the pick below you can see the fuel hose connected to the carb and to the left of it are two other brass hose fittings, that I assume are drains, should they both have rubber hoses on them and what do they actually do?
Re: 74 CB350F Carb Question
« Reply #1 on: September 19, 2015, 04:50:15 PM »
Air vents to equalize pressure as carbs drain and fill....
Offline chewbacca5000
  • I polish covers!
« Reply #2 on: September 19, 2015, 04:58:30 PM »
Flybox for the win.  Just what he said.  They equalize pressure.  Mine are missing wonder if that could cause an overflow issue?
« Reply #3 on: September 19, 2015, 05:04:24 PM »
No,  ut if they were clogged, they will cause slow filling of the bowls...
  • I polish covers!
« Reply #4 on: September 19, 2015, 05:12:45 PM »
O well here's to hoping.  Round 2 tank / carb clean.  Think I just going to RedKote this sucker and be done with it.
Offline gtmdriver
« Reply #5 on: September 20, 2015, 11:20:40 AM »
If the vent pipes are missing water can get in to the float chambers. They should loop up then down again or lead somewhere where nothing can drop in.
The drain tube are the ones which come out of the bottom of the float chambers. They should all have tubes on too.
Offline GizmoDuck
« Reply #6 on: September 21, 2015, 04:07:42 PM »
So one fuel connector, two air vents next to that, and then four drains at the bottom of the float chambers?
Offline gtmdriver
« Reply #7 on: September 22, 2015, 06:39:50 AM »
Yes. That's it.
I used bio-fuel proof Nitrile rubber for the fuel and drain lines and I used PVC (because I ran out of nitrile) for the vent tubes.
The fuel line should be 5mm I.D. and the drains and vents should be 3mm I.D.
