Author Topic: Maduncle has FINALLY got himself a CB750K  (Read 34643 times)
Offline maduncle
  • Don't confuse me with a
Re: Maduncle has FINALLY got himself a CB750K
« Reply #175 on: August 22, 2016, 03:23:07 AM »
Update time:
300 miles in and the engine is great, I have done one oil change, adjusted the cam chain tensioner and tappets and got most of it just right.
The only thing to fail on me so far is the speedo - I need to track down the cause but I think it is the drive unit on the front hub. Hopefully it is not the brand new little gauge, 'cos if it is - that means doing a lot of re-wiring.
Next task is to wash it after the weekends blast before benching it to fix the speedo - those Gippsland country roads get a lot of mud on them from the local farm tractors, which ends up all over a bike on a wet weekend.
CB750K2 (only slightly modified)
« Reply #176 on: August 22, 2016, 03:35:49 AM »
Looking good Cliff, make sure you drop your oil filter and replace it ASAP, there'll be lots of swarf floating in your oil from the new pistons and rings etc, that could do lot of damage if you leave it. Cheers, Terry. ;D
Offline maduncle
« Reply #177 on: August 22, 2016, 03:51:16 AM »
Yep - did that at 90km, there was a bit of swarf on the magnetic sump plug, a few bits of small crud on the filter and a light sheen in the oil - but nothing major that I could see. Pain in the butt getting that filter off as you need to take the 4 into 1 pipes off to get to it.
« Reply #178 on: August 22, 2016, 05:39:41 AM »
Yep, that's why I mentioned it Cliff, some folks might decide not to change the filter as regularly as they should because they have to remove the pipe to do so, but when you're running in a new engine, it's critical. Good thing with that old Yoshi is it doesn't weigh much. ;D
Offline TomsK8resto
« Reply #179 on: August 25, 2016, 04:17:38 PM »
Cliff,
Now that you have some seat time on this bike, what is your impression of the seat itself?    BTW, the bike looks good.
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline maduncle
« Reply #180 on: August 28, 2016, 01:46:15 AM »
Cliff,
Tom
Hi Tom,
The seat is comfortable and has enough padding, I can sit well back into it and get a good riding position, it is just a bit wide for me I reckon, if it tapered in more at the tank end I would be happier.
« Last Edit: August 29, 2016, 04:52:05 AM by maduncle »
Offline TomsK8resto
« Reply #181 on: August 28, 2016, 05:25:05 AM »
Cliff,
Tom
Hi Tom,
The seat is comfortable and has enough padding, I can sit well back into it and get a good riding position, it is just a bit wide for me I reckon, if it tapered in more at the and end I would be happier.
Thanks for the seat report Cliff!
Tom
'69 CB750 long gone
'76 CB750F gone
'09 H-D Roadglide
Offline Sigop
« Reply #182 on: August 28, 2016, 09:17:48 AM »
I just read from start to finish.  Great job.  I am only just beginning to recondition my 750 K3.  Much for me to learn from you and so many others.
CB750 K3  Original Owner and Operator
Offline maduncle
« Reply #183 on: December 04, 2016, 02:39:07 AM »
Still loving this bike and riding it regularly.
But the other day I had the set up whilst starting it and I noticed a spark jumping from the frame to the battery tray as I hold the starter button down to start the bike.
Do I have a bad earth and should I be running an extra earth wire from the frame to the battery tray?
« Reply #184 on: December 04, 2016, 02:47:25 AM »
Sounds like a good idea Cliff, I always run an earth from the frame to the negative terminal on the battery, and another one from the top of the engine case to the negative terminal, and one from the coil mounting bolts to the negative terminal. Cheers, Terry. ;D
Offline maduncle
« Reply #185 on: December 06, 2016, 01:40:11 AM »
Thanks mate - I will get all earthy on the weekend.
« Reply #186 on: December 06, 2016, 10:39:46 AM »
Would your oil filter come off if you trim the fins ? Sucks to have to pull pipes , but goid time to clean them.
