Tech Forums > SOHC/4 Bikes
Tapered Steering Bearings Thread
<< < (10/128) > >>
clarkjh:
I'm going to mic the races sometime this winter, I have it apart anyway, and give the specs to the local bearing dealer.  I can get the 6302 2RD front bearing for about $3 CAD a piece.  Can't see the tapered bearings being a whole lot more.
James
Quail "Owner of the comfortable k8":
I just replaced the orig. bearing with tapers on my K8.  I sat it up on the centerstand and turned the handlebars, they seems eay enough and had no hard spots.  But after I removed the front wheel I could really feel a flat spot in the steering.  The old grease was long dead and the balls where far from round.  I feel like I have power steering now and the cornering is smoother now too.  My dust cover was part of the adjusting nut also.
lassenc:
I was wondering if they quality is the same at davidsilver on the tapered bearing, they are almost half the price, and then I don't need to pay taxes like I do at US shops.
I bought my tapers of ebay 40.00.  took the part numbers off them and bought timkin bearings local for 18.00.  I just resold the ebay bearings for 40.00.  I only wish I would have thought to keep the old bearing numbers.  If anyone needs to replace the lower dust seal I bought a pack of 10.  I just have not got around to listing them yet.  I love the tapers, you can not believe the change.  And my old bearings passed all the test as fine!
crazypj:
One thing about fitting taper roller head bearings is they are about 1/8" inch taller than stock. It isnt a problem with aftermarket headlamp 'ears' but the stock move about a bit. need to fit some sort of washer on the fork tubes to prevent this and keep the standard rubber mounts slightly compressed ( or dont go out in the dark)
PJ
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
