Tech Forums > SOHC/4 Bikes
Tapered Steering Bearings Thread
bryanj:
Might look like two pieces in each end but they are just machining marks
doug_id:
--- Quote from: Brunow on November 15, 2006, 05:04:17 AM ---I'm planning to place some new "bearings" would these be any good? (50€ts)
They say they improve general steering and reduce the vibration of your front wheel in high speed
--- End quote ---
Those are the ones I have as well. I am just prepping the frame for powder coating now so will not be installing them until that has been done.
Not quite sure what the washer/spacer does? Does it go in the bottom above the actual bearing?
Doug
spitfire:
If you enter JOHNK6 into the search box and bring up "How to rescue a CB750 from the garbage dump" on page 3 there are some great photos of how to fit the bearings and where the spacer goes.
Cheers
Den
doug_id:
--- Quote from: spitfire on November 15, 2006, 07:30:57 AM ---If you enter JOHNK6 into the search box and bring up "How to rescue a CB750 from the garbage dump" on page 3 there are some great photos of how to fit the bearings and where the spacer goes.
Cheers
Den
--- End quote ---
Hey thx Den........wow that is some project that Johnk6 took on.
Here is a link direct to the page that shows the new bearings being installed.
http://www.sohc4.us/forums/index.php?topic=13258.30
doug_id:
yes me again ::) ::) ::)
Assume these parts on the bottom of the steering stem must go as well? Any hints for getting these off. Not much there to hit with a rod and hammer and then can only get to one side. It is on tight!
here is a pic......
Thx!
Doug
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
