Author Topic: cb550 new rims  (Read 2518 times)
Offline mikecb550
cb550 new rims
« on: September 22, 2015, 04:10:20 AM »
Hello. I am replacing the rims and spokes on my 78 cb550.The old rims are rusted so i will replace with alloy rims and stainless spokes.
I would like to ask peoples opinions please on changing the rim sizes or not.I've read that some people put an 18" rim on the front. also widening to 2.15" front and back?
any thoughts appreciated or links to previous posts.Many thanks.Mike.
Offline toolguy
Re: cb550 new rims
« Reply #1 on: September 22, 2015, 04:56:30 PM »
I put a stock cb750 rim on my 71 CB500 to gain the width. .
works fine
Offline calj737
  • I refuse...
Re: cb550 new rims
« Reply #2 on: September 22, 2015, 05:45:36 PM »
You have ample room on the rear to even run a 4.25" rim, if you so choose. The 18/18 front and rear is popular among many, and a 2.15" front and 2.5" rear make a very stable and well handling combination.
Offline mikecb550
Re: cb550 new rims
« Reply #3 on: October 22, 2015, 09:44:07 PM »
Hi. Thanks for the Replies.
I have my eye on some 18" Cerchio Borroni Record style rims from a seller in Italy on ebay. I think other folks here have used them.I need to find out the length of the front spokes for the reduced front rim diameter, If anybody knows please? Buchanan's look like they sell a kit for 18" rim. I am wondering if there needs to be allowance in spoke length for rim with dimple or not? Or if there is anything else to look out for, like the angle of the spoke holes? Thankyou. Mike.
Offline calj737
  • I refuse...
Re: cb550 new rims
« Reply #4 on: October 23, 2015, 02:59:32 AM »
The spoke length is different for dimpled rims. Also, the nipple is different.
My strongest recommendation is to send your hub and rim to Buchanans and have them install the spokes. Yes, it costs a bit with shipping to-and-fro, but it will insure the correct fitment the first time. Or, you can call them and have a detailed discussion and probably get the correct spokes from them and DIY.
Offline mikecb550
Re: cb550 new rims
« Reply #5 on: November 14, 2015, 02:40:20 PM »
I live in Sydney and Ive found a local guy to lace and true my new 2.5 & 2.15 X 18"rims.
Unfortunately I have disassembled the rear rim without measuring for an offset.Does anybody know what this offset measurement is please, or will just having the correct spokes automatically set the offset correctly?Thankyou.
Offline Powderman
Re: cb550 new rims
« Reply #6 on: November 14, 2015, 02:47:38 PM »
What offset are you referring to? Were any Hondas made with an offset rim? None that I know of.
Offline mikecb550
Re: cb550 new rims
« Reply #7 on: November 14, 2015, 03:10:16 PM »
I was referring to the lateral distance from the outside edge of rim to the hub spoke flange and whether or not it is equal on either side of the rear wheel?  Is there no offset on the cb 550?
I have never had a wheel re spoked before and are just wanting to be informed for the task.Thankyou
Offline calj737
  • I refuse...
Re: cb550 new rims
« Reply #8 on: November 14, 2015, 03:13:31 PM »
There is none. Not on any CB ever made by Honda.
Offline Powderman
Re: cb550 new rims
« Reply #9 on: November 14, 2015, 05:25:20 PM »
The center of the hub spoke flanges should be centered on the rim.
