Regarding the start valve, as long as the bevel on the bottom is good, and it slides freely in it's bore so the spring holds it shut, I wouldn't bother replacing it. I don't think you have the mechanism that operates them anyway.
Are you sure the aux are 2.5? 4.5 are the most common.
Lastly, the carb I have been taking pics of has a damaged top, a dented float, and some missing parts. If you get into a bind, or just flat give up, I'll sell you the main body, stripped of most of the brass, for $50 plus shipping.
