Gregg, those 34mm chokes are too big for a stock 736 motor. If you insist on trying them, go to a much larger main jet, maybe 125-130?
Also, before you mount the carbs on the bike, fill the float bowls with gas and verify the accelerator pumps are functioning properly. Once mounted, it's almost impossible to see the stream, as the nozzles are located deeply into the throats, and pointed the other direction.
