Why would anyone get to this point and not replace valve seals and lap in the valves? it is so easy. Dan
That's the plan, but the deposit or lack of on valves and in the chamber can tell you what was going on. Yesterday I removed valve springs and did leak test using rubbing alcohol with just valves sitting there. They all leaked in order (fast to slow) 4,2,1,3.
I always had a problem with #4 in vacuum synchronization.
4 and 2 leaked dry in 2 minutes, but #3 took 6 minutes to leak completely.
