Author Topic: Honda Cb 400 Four 1977  (Read 4385 times)
Offline Paulo Fonseca
    • CafeRacer.pt
« on: October 02, 2015, 05:52:55 AM »
Hi,
I'm Paulo from Portugal and I'm the new owner of a 1977 CB 400 Four that is in really bad shape and didn't run for more than 10 years.
Before I rebuild the bike, I wanted to know if the engine was working, so I cleaned up and unlock the carbs. One of them is leaking and they need to be tuned and it doesn't have the air filters, but was enought to put the bike running.
One of the problems I've found so far it's that the engine makes a noise when I put one gear in the bike and start to release the clutch. The noise keeps going with the bike running. Sounds like a rotating whistle (I will try to make a movie). Any idea?
I was expecting more of this engine ... compared with a CB 400 N from 19884, the four is much slower (I know that is not tunned), but this big difference in performance is normal?
The engine will be repaired in a mechanical, but as you have more knowledge of this engine, any suggestion is welcome. Common problems, improvements that can be easily made, ...
Thanks,
Paulo
« Last Edit: October 02, 2015, 06:00:56 AM by Paulo Fonseca »
    • CafeRacer.pt
Re: Honda Cb 400 Four 1977
« Reply #1 on: October 02, 2015, 06:40:19 AM »
Thanks for the reply. The whistle cames from the engine, and it's only when I leave the cluch and running the bike, in neutro the engine don't makes any noise. It's like something spinning...
I've wrote that the carbs didn't have the filter because I suspect that it could cause less power, but it's a big difference. Does anyone ever run this to bikes that could tell something about how they run?
Offline vames
« Reply #2 on: October 02, 2015, 08:21:32 AM »
A well running cb400four should produce a lot more power than the 1980s cb400twins. Running the 400 without the airbox will inform you that the engine runs, but it won't tell you much about its capabilities.
« Reply #3 on: October 02, 2015, 08:32:10 AM »
Without the airbox mine needed 1/4 choke to ride it. It is possible to rejet the carbs to run without the airbox but it's easier to just put one back on.
    • CafeRacer.pt
« Reply #4 on: October 02, 2015, 09:24:47 AM »
I can year the noise even when release the clutch and use the brakes so the bike don't move.
I will make a movie on the weekend.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: October 02, 2015, 09:39:19 AM »
Awesome and Welcome! No offense but that is the ugliest 400F I've ever seen  ;D You've got your work cut out for you but the board can help with any of it. Any plans for it? Restoration? Cafe?
The whistling noise and lack of power might be contributed from an air leak in the intake somewhere. When idling spray some ether (starting fluid) around the intake and see if it changes engine speed.
I've been to Portugal and absolutely loved your country. The Portuguese are a super friendly people. And Lisbon is a beautiful city. Sorry for the gushing but I am reminded I haven't travelled anywhere outside the US and Canada for 3 years. Time to go see more of the world. On 2 wheels will be even better!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
    • CafeRacer.pt
« Reply #6 on: October 02, 2015, 11:32:26 AM »
Hi Duanob
Thanks for the coNot a valid %s URLmpliments about my country and the portuguese people. Although a samll country, we have sll kind of landscapes,  mountain, land fields, beach , snow ... and yes, we are very friendly.
I like to think about myself as the saver of this bike ...it's not preatty right now, but will be soon, as a cafe racer (with most of the original parts)
About the noise, here it is the video
« Last Edit: October 02, 2015, 12:13:09 PM by Paulo Fonseca »
« Reply #7 on: October 02, 2015, 11:36:20 AM »
go on and save that bike, Paolo!
as mentioned, get the honda manual and be diligent in doing all of the 3000mi maintenance items.
start a build thread in that section of the forum, and keep us updated with your progress, photos, and questions.
good luck!
~fly
    • CafeRacer.pt
« Reply #8 on: October 03, 2015, 07:46:10 PM »
Anyone can help with the noise? Video above
Offline MoMo
  • Ride like you're invisible
« Reply #9 on: October 03, 2015, 09:14:18 PM »
will the bike move forward? welcome...Larry
    • CafeRacer.pt
« Reply #10 on: October 04, 2015, 01:24:34 AM »
Yes, the bike runs and all the gears work fine. I just use the brake to make the video and show.the noise.
« Last Edit: October 04, 2015, 07:28:37 AM by Paulo Fonseca »
Offline Redline it
  • thread killer
« Reply #11 on: October 04, 2015, 05:45:40 AM »
the reflector on the front fender is sweet.
Offline MoMo
« Reply #12 on: October 04, 2015, 06:14:24 AM »
Certainly sounds like a bad bearing, either clutch or trans.
Wobbly
« Reply #13 on: October 04, 2015, 07:01:17 AM »
Hi Duanob
Welcome to this site. I went to Portugal in 1982 to go to a mc meeting in Faro and had a great time. Portugal was very inexpensive back then. Nice place to ride a bike.
    • CafeRacer.pt
« Reply #14 on: October 04, 2015, 07:35:05 AM »
Hi wobbly, when I made 18 years old I made 800k on a bike to went to the faro "international" bike meeting. .. its great, I hope ta have this cb 400 four working soon to make the same trip with it. Loved your pictures :) makes.me.want to go there write  now
« Reply #15 on: October 04, 2015, 07:36:26 AM »
Welcome from Texas.
« Reply #16 on: October 04, 2015, 08:01:51 AM »
Take the clutch apart to check it, and if there is a way, check that the topend is getting oil to the rockers..
 Pull off some of the rocker covers..see if it's oily in there.
    • CafeRacer.pt
« Reply #17 on: October 04, 2015, 01:59:19 PM »
 I also would say that the noise came from the clutch, because we can ear it with the bike stoped
Thanks for the welcome.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #18 on: October 04, 2015, 03:37:54 PM »
I thought it was supposed to have a red&green lens to help identify port and starboard sides?
CoolBoat400
Offline Redline it
  • thread killer
« Reply #19 on: October 08, 2015, 09:41:01 PM »
CoolBoat400
CoolBoat Patend that like now! That might be as intense of an inventive design at least as much as what Led's did for the mono filament light world, shoot, make it an led. And make the whole front fender a quick release and you could mount that fender on your bow, because if you left it on in the parking lot, it'd be gone sure as anything. That chrome, wouldn't it be also a radar target for foggy days? They'd probably redesign the entire highway system just like a port...no more stops signs. I'd buy one.
  • Holy Cow! I'm a
« Reply #20 on: October 08, 2015, 11:03:54 PM »
CoolBoat400
Forge an Anchor Shaped kickstand and call it Cafe' Nautique.
Lay teak on top of the tank and make a custom fit fuel cap.
Offline Rob69
« Reply #21 on: October 09, 2015, 12:26:35 AM »
Take the clutch apart and inspect the bearing. It should rotate smoothly D ; no notchiness or binding should be felt. While you're in there inspect everything for wear and/or damage, as per the service manual.
Sent from my C6730 using Tapatalk
