Author Topic: 1204cc - 120rwhp track bike by RPE in Oz  (Read 4979 times)
Offline hotdog
« on: October 05, 2015, 01:52:38 AM »
Good to see front brake still squeaky....
https://www.youtube.com/watch?v=0daxpHJcASg
« Last Edit: October 05, 2015, 02:09:22 AM by hotdog »
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline bear
  • Leeton in Australia
Re: 1204cc - 120rwhp track bike by RPE in Oz
« Reply #1 on: December 08, 2015, 12:22:23 AM »
Just a bit shy of our "little" motor @124RWHP ;D
« Reply #2 on: December 08, 2015, 01:44:03 AM »
This one says 130 to 150 HP....
« Reply #3 on: December 08, 2015, 02:15:41 AM »
Offline kmb69
« Reply #4 on: December 08, 2015, 08:30:20 AM »
1204cc is a 78mm bore! How they doing that?
« Reply #5 on: December 08, 2015, 10:31:09 AM »
I'd almost bet they'd ship you an engine to play with ;-) then you might skip those slow 10's.
« Reply #6 on: December 08, 2015, 03:49:40 PM »
Stroker.... ;)
Offline kmb69
« Reply #7 on: December 08, 2015, 04:37:06 PM »
RR, They are claiming to have a stock stroke. That's why I ask the question. 78mm x 63mm x 4 is 1204cc.
Their 1300 is a stroker.
« Last Edit: December 08, 2015, 04:40:09 PM by kmb69 »
« Reply #8 on: December 08, 2015, 04:39:57 PM »
Ahh, the first video I posted says its a stroker, they must have upgraded the engine... ;)
I reposted this in the HIPO section... ;)
Offline kmb69
« Reply #9 on: December 08, 2015, 04:42:47 PM »
RR, They're claiming the 1300 is a stroker. The 1204 claims to be stock stroke on the videos I saw.
« Reply #10 on: December 08, 2015, 04:57:56 PM »
Yeah, I know, I only read the second one originally  ;)
I could ring them and find out, the make their own rods, maybe they made the block..?
Offline kmb69
« Reply #11 on: December 08, 2015, 05:02:49 PM »
Sure be nice to know. Pretty sure they would have to be spreading the rod spacing to get to 78mm.
« Reply #12 on: December 08, 2015, 08:13:35 PM »
+1 on the 1200 with stock stroke and stroker in the 1300.
Just buy one of them dammit. One each  ;) ;D
Offline hotdog
« Reply #13 on: December 08, 2015, 09:16:02 PM »
Buts it's more fun to build your own..?
Sent from my HTC_M9u using Tapatalk
« Reply #14 on: December 08, 2015, 11:55:48 PM »
Heres what they said Keith  ;)
As you can understand we are in a delicate position when revealing secrets that costs us a lot of R&D.
I can confirm we use offset rods, made in house from billet high strength steel.
We heavily modify the stock barrels to suit the pistons (this is the magic part).
Race head is also unlike normal cb heads.
We can make up to 1300cc on the std stroke. That will be our next race engine to max out P4 rules.
Offline hotdog
« Reply #15 on: December 09, 2015, 12:40:07 AM »
I bet my left testi they're running offset barrel/rods combo, allowing bigger bores.....only need one right.?
« Reply #16 on: December 09, 2015, 01:07:30 AM »
Gday mate, I copied this thread into the Hipo section for the speed freaks... ;D ;)
http://forums.sohc4.net/index.php/topic,153581.msg1756028.html#new
Offline hotdog
« Reply #17 on: December 09, 2015, 01:11:27 AM »
Great thanks
Offline kmb69
« Reply #18 on: December 09, 2015, 06:15:20 AM »
Thanks RR. Just as I suspected. Very impressive their engines stand up to road racing in that configuration. Pretty sure they are rearranging the cylinder studs as well. I have studied this setup in my CAD system. It gets crazy!  ;D
« Reply #19 on: December 09, 2015, 02:46:55 PM »
Yes, I was thinking they would have to rearrange the studs, theres simply not enough room otherwise...  What size piston would you need to get 1300cc on stock stroke..?
Offline kmb69
« Reply #20 on: December 09, 2015, 03:19:46 PM »
81mm x 63mm x 4 = 1298.56cc
82mm x 63mm x 4 = 1330.82cc
« Reply #21 on: December 09, 2015, 03:28:25 PM »
That is BIG   :o
