Author Topic: CB750 master cylinder upgrade - first ride  (Read 8391 times)
78CB750F1
« on: October 31, 2006, 09:55:17 AM »
I just got back from my first ride after replacing the stock setup on my CB750 F1 (single front disc) with a Nissin 14mm remote master cylinder assembly and Goodrich braided line - I junked the pressure sensor for the brake light as the Nissin assembly has an integrated switch.  The improvement is amazing!  I find that the lever doesn't have quite enough travel, but I am willing to overlook that for how much the braking has improved.
Anyone who wants better braking and doesn't mind the non-stock appearance of a modern assembly should go for the upgrade - it's well worth it.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: CB750 master cylinder upgrade - first ride
« Reply #1 on: October 31, 2006, 10:37:58 AM »
Details and pictures required.
Did you stick with the stock disc / caliper?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
78CB750F1
« Reply #2 on: October 31, 2006, 11:03:06 AM »
I will try and get some photos up soon.  The Nissin assembly looks great and doesn't seem too out of place on a vintage bike.  I stayed with the stock caliper and disc - someday I would like to resurface and drill the disc for better braking but it is good enough for now...
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: October 31, 2006, 11:22:32 AM »
I have the same setup on my scoot - and it was a HUGE improvement over the stock master.
Pic of my setup is below...
« Last Edit: October 31, 2006, 11:24:31 AM by ProTeal55 »
Offline doug_id
    • My Cafe 550 Project Gallery
« Reply #4 on: October 31, 2006, 11:59:55 AM »
Sounds like a good idea......where did you purchase it?
Doug
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
« Reply #5 on: October 31, 2006, 12:00:17 PM »
I installed a new remote MC from a Suzuki SV1000.  It is a Nissin and it works very well, especially with the new braided Russell lines.
Sparty
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
78CB750F1
« Reply #6 on: October 31, 2006, 12:28:57 PM »
Doug - I purchased mine new from a local dealer.  You could get a used one for less off some modern sportbikes.
Offline Geeto67
  • A grumpy
« Reply #7 on: October 31, 2006, 02:35:52 PM »
got a model or part number for the braided line and MC - makes looking it up in the part unlimited cat a lot easier.
Maintenance Matters Most
« Reply #8 on: October 31, 2006, 03:05:26 PM »
Parts Unlimited and Tucker Rocky carry them. Dennis Kirk should list them. Check them out here   http://www.shindypro.com/
Offline Geeto67
  • A grumpy
« Reply #9 on: October 31, 2006, 04:04:42 PM »
is this the right banjo bolt or does it not matter:
Use with M10 x P1.25 banjo bolt.
I assume you are talking about this MC:
http://www.shindypro.com/catalog/each_q_ptype.key29.html
What is the correct line I need (if you can;t gimmie the part # at least confirm the banjo bolt sizes)
Offline sparty
    • Gallery
« Reply #10 on: November 01, 2006, 06:40:43 AM »
M10 x P1.25 banjo bolt - YES
I am running a 9 inch braded Russell line from the MC to the first connection at the stem.  My Russell line is the Pro Street series.
I installed the chrome banjos by Russell.  you can see one in my pic above.  It is a 90 degree off of the MC.  My banjo bolts are also chrome and they are Russell, they came with sealing washers.  the bolts, banjos, and lines were under 60 bucks.  i got the MC off of ebay for $56 NEW!  They retail for $130 - $140.
Sparty
Offline doug_id
« Reply #11 on: November 02, 2006, 07:09:09 AM »
Sparty
Hi Sparty,
So you have braided line down to the first conection below the headlight then the stock line the rest of the way to the caliper.   Do you know if russel makes a connection that will fit directly to the steel pipe that goes into the caliper or one that would go directly into the caliper?
I would like to get one line that goes from master directly into the caliper or one at least directly into the stock steel pipe that goes into the caliper.
Thx,
Doug
02 Concours
78 CB550
Offline ProTeal55
  • Est1968.com
« Reply #12 on: November 02, 2006, 07:24:30 AM »
I ditched the stock "steel pipe" and went with new line from the master to the Guzzi "Y" block , then from their to both calipers.
Offline doug_id
« Reply #13 on: November 02, 2006, 07:32:30 AM »
So russel does have a connecter that will go directly into the stock caliper?   As it does not use a banjo bolt
Doug
02 Concours
78 CB550
Offline ProTeal55
  • Est1968.com
« Reply #14 on: November 02, 2006, 07:37:19 AM »
You are correct sir, as I am sure many other manf. sell this part as well...
Offline tsflstb
« Reply #15 on: November 02, 2006, 07:43:45 AM »
I bought a CBR900 master cylinder on Ebay and it came with a couple of braided steel lines.  They fit right up to the stock caliper - same banjo bolt and everything, so I'd think most modern Nissin brakes use the same fittings.
Offline doug_id
« Reply #16 on: November 02, 2006, 08:03:01 AM »
Ah, so the regular banjo bolts will screw into the stock caliper fine?
That's great!
Thx,
Doug
02 Concours
78 CB550
Offline Chris Liston
    • http://christopherliston.com
« Reply #17 on: November 02, 2006, 09:42:11 AM »
On my 550 I updated the master and used all Russel stainless lines.  I kept the hard line to the caliper and ordered this part from Flandersco.
This Order is for the following Parts:
PartNo1..........226-41470
Qty1.............1
Desc1............Adapt Ftg #3ANmx10-1.25f
Unit1............17.95
Total1...........17.95
Here is the site and pic..  Works like a champ...
http://www.flandersco.com/action.lasso?-search&-database=_Flan_Levers.fp5&-layout=Russell2&-Format=RussellResultsP.html&-Error=RussellErrorP.html&-Operator=Contains&Catagory=Russell%20Part
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
Offline doug_id
« Reply #18 on: November 02, 2006, 11:11:10 AM »
nice..... ;D
So the stainless line attaches to this fitting with a regular banjo bolt that came with the line?
Thx,
Doug
02 Concours
78 CB550
