Author Topic: Trouble fitting throttle cables  (Read 634 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: October 07, 2015, 10:46:34 PM »
I am having trouble fitting my push/pull cables into my PD46C throttle. This is a picture of the pull, it seems logically the end would fit into the groove but doesn't. I don't know where the push is supposed to attach either.
Offline Garage_guy_chris
Re: Trouble fitting throttle cables
« Reply #1 on: October 08, 2015, 12:49:38 AM »
It looks like your trying to push it straight in from above. take the cable body off the carbs, turn the cable facing away from the quadrant and feed the lug in from the side, then rotate down and attach the cable body to the carbs
« Reply #2 on: October 08, 2015, 04:30:57 AM »
Yes, it slides in from the side.
« Reply #3 on: October 08, 2015, 06:31:51 AM »
yep, goes in from the side.
twist your throttle cable or rotate your bars to give you a little extra slack.  once the end (you have pictured there) is in place, fit the cable sleeve end into its holder and secure the lock nuts.
Offline AlekStooge
« Reply #4 on: October 08, 2015, 09:16:48 AM »
Thanks old timers I couldn't fit it from the side till I loosened the nuts.
