Author Topic: 1976 CB750F - first bike, first build - mild cafe  (Read 37225 times)
Offline GritCity750
  • 5th time's a charm!
Re: 1976 CB750F - first bike, first build - mild cafe
« Reply #25 on: October 25, 2015, 04:38:02 PM »
Definitely want to check that you can see light through those pilots!  Compressed air is useful to clear them out after a soak as well.
Float measurement is easiest with the carbs upside down, at an angle so the floats are hanging just starting to touch the needle.
Great resource with picture instructions:  http://www.salocal.com/sohc/tech/carb/asmpg_mgs/flthgt.htm
You don't have to seperate the carbs to change the needle clip position, but you do have to pull away the throttle body to unscrew the tops obviously.
I wouldn't go moving needle yet, start at stock position, middle groove, get main-jet right and idle circuit dialed in and see how it is.
I have a 76F with carpy 4into1 as well, I think you'll absolutely need to jet up a bit, it's a very open pipe.  115's should be good to start, do a wot plug chop and if looks rich start stepping down.  I've been through almost every intake option since i built the bike and have a full set of jets from 105-130, mainly just because i like to play.  I've run open stacks, uni-filter pods, and the stock airbox now with k&n filter & intake modding. I'm actually in the process right now of leaning it back out for the air box.  Just like anyone will find with 5 minutes research, i could immediately feel the throttle transitions are way smoother with the airbox and no turbulent air passing things on the highway.
I currently have 122.5 mains and 42 idles with needle one clip richer from running v-stacks, it's running very rich all around with airbox now obviously.  No black smoke but fuel ring on the plugs is black and sooty and it feels lazy.  I'll be taking them back to 40 idle 118 mains this weekend to see how that is.  Will be interested to hear how yours looks with the 115's.
75/76F is my favorite, looking forward to seeing more of yours as you  progress.
+1 for sure. I run a Carpy Dunstall 4into2 with K&N pods and 118 jets with 40 pilots works well. I picked up a few sets of different sizes of jets from 4into1 and (i think they are about $2.50 each) and played with them until i found the best setup. Once i got it figured out, I replaced them with the OEM Kehhin jets ($4.50 each).
Offline Gooseman
« Reply #26 on: October 26, 2015, 07:54:24 AM »
Yes to the washers to fill that play in the shock clevis's.  Some shock builders will include shim washers as they're commonly needed.
Offline riffman12
« Reply #27 on: October 26, 2015, 09:09:11 AM »
great, thanks. What about the top? Does that look OK as is?
Offline riffman12
« Reply #28 on: October 27, 2015, 12:55:38 PM »
anyone know if the top of those shocks look OK? Or if I need some extra spacers in there?
Offline Gooseman
« Reply #29 on: October 27, 2015, 06:46:47 PM »
Tops look fine to me in the pic as long as they tighten down ok.
Being the gap on the bottom clevis is on the outside of the mount, they definitely don't need a washer behind them.
Only real reason for the washers on the bottom is so you don't bend and weaken the cleavis.
Offline riffman12
« Reply #30 on: October 28, 2015, 10:02:49 AM »
hmm so you're saying you don't think I need a spacer at the bottom? Or I need one in between the clevis and the swingarm?
I've started building the seat pan for my upholstery. Got the template all worked out last night. It was a major pain because the seat gets narrower towards the front. Next step is actually cutting it out of aluminum sheet and bending it to fit.
big thanks to CB750 Cafe Racer Fan for the help with this  :D
Offline riffman12
« Reply #31 on: November 01, 2015, 09:59:33 PM »
OK so this rear wheel is going to fight me every step of the way.  >:( >:( >:(
So first I had some issues with the wheel bearings. I was tapping in the brake rotor side (the one with the retainer) and tapped it a bit too far so that it smushed up against the collar on the inside. After a lot of swearing I got it to back out a bit until it was just snug up to the collar, but could still move the collar.
but now I have a whole new issue. My brake caliper bracket is rubbing against my brake rotor. The spacing in the rear axle is wrong somewhere. See pics:
Here's the rest of what is going on, in case someone can see something that does not look right
As you can see it is nowhere near centered in the bracket. I'm trying to figure out where the spacing can possibly be off. Here's my thinking so far:
1) I am using a wheel from a '79 CBX, but everything else here (axle, spacers, brake bracket) are from a '77 750F.
2) I double checked that the brake bracket was the correct fit, and indeed the CBX and 750F brackets are identical (same part number)
3) I' wondering if perhaps the two little collar / spacers on either side of the wheel were spaced different for the CBX. The part numbers are different.
4) I wondered if perhaps the little spacer / collar is not far in enough, but it pushes up against the bearing, and the bearing has no more room to go in.
I figured that all the Comstars would share the same spacing for everything regardless of bike model. Am I wrong in thinking that?
Here's how it looks on the bike...one day when I stop hitting road blocks like this  >:(
I know it's a bit of a unique issue, but can anyone shed some light on this?
My next step might be buying a full rear axle from a CBX... but I'm worried it won't fit in the 750 swingarm or something silly.
« Reply #32 on: November 02, 2015, 09:21:41 AM »
Perhaps you need a 75/76 caliper? Check in with Wilbur aka madmtnmotors. He may be able to compare the 2 calipers for you.
Offline riffman12
« Reply #33 on: November 02, 2015, 09:34:53 AM »
hmm I don't think the caliper or the bracket are the issue. The wheel, brake rotor, and caliper bracket are all from a CBX. The issue seems to be that little collar / spacer between the hub and the caliper bracket.
so frustrating. I just want to get the wheels on  :(
Offline riffman12
« Reply #34 on: November 03, 2015, 09:20:19 AM »
OK well I ordered a complete CBX rear axle complete with spacers off eBay. Hopefully that helps some of my issues at the back.
My next obstacle is my front sprocket. I ordered a brand new 17T sprocket. Went to mount it and the bolts didn't feel quite right. I figured they were just a bit gummed up from being in the old sprocket. Now it seems the threads weren't quite right and I may have damaged them.
Is that normal for the threads on a new sprocket to be different than the old ones? That seems odd to me.
Offline riffman12
« Reply #35 on: November 18, 2015, 01:44:52 PM »
OK so here is the latest. I'm hearing from several sources that my '77F swingarm is wider on the left side than my '76F bike. I took these pictures to see if anyone can confirm this.
The only reason I'm puzzled by all of this is that I purchased the bike from someone who (as far as I know) rode it with this frame / swingarm combination and I think he would have noticed if the shocks were crooked.
What do you guys think? I think I am seeing that my left shock kicks out further than my right one.
Ignore the wheel not being quite centered. I've got some axle / spacer / bearing issues I'm working on
PS: Thanks to all that I have been sending PMs to trying to help with this.
Offline riffman12
« Reply #36 on: November 19, 2015, 08:37:24 AM »
hm that's a good idea. And just put a spirit level across the top of the bike or something? to make sure everything's level?
« Reply #37 on: November 19, 2015, 11:58:02 AM »
Yeah, thats not a F/F1 arm and looks like a F2/F3 from the axle adjuster area. Being that, it is 10mm wider on the left. I had an 10mm adapter and spacer made. When I tried different shocks (3 brands) I discovered the top mount on each is a different width with the Honda shock being wider. I don't know how much difference it will actually make but the angle will be different. Can't do pix now as I'm about to hit the road again.
« Reply #38 on: November 19, 2015, 03:21:19 PM »
What Jerry MF says, it looks like the left shock needs to come out at the top.
« Reply #39 on: November 19, 2015, 05:05:12 PM »
10mm offset shock mount adapter
This is in conjunction with the 10mm offset swing arm left side.
Stock shock mounted using the adapter with F2/F3 swing arm. Notice the clearance of the sprocket plate and the arm with this setup. NO clearance using the 75/76 F arm (-10mm offset) and the 77/78 sprocket carrier that is necessary for the alignment with the 77/78 engine.
The Redwing shock and the 'other' shock (forgot the Italian sounding name) are both narrower at the top mount and leave a small space where the top shock mount could move laterally. Washers/spacers should probably be used in this instance.
« Last Edit: November 19, 2015, 05:15:20 PM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #40 on: November 20, 2015, 04:25:05 AM »
I replaced the stud.
Offline riffman12
« Reply #41 on: November 20, 2015, 10:47:15 AM »
as nice as it would be to replace the stud altogether, I'll probably go the route Jerry suggested. Any tips on where to get that offset shock mount adapter? Or do I need to get it done custom at a machine shop?
My biggest question now is...why am I even going through all this work to make the wider swingarm work? My engine is the narrower '76F engine, so I feel like I'm trying to force this wider swingarm, custom offset sprockets etc. for no added advantage. Am I right in thinking this?
Scratching my head trying to figure out why the previous owner even installed the later swingarm in the first place...  ???
But if I go back to  the '76F swingarm:
a) I would need to find and buy the swingarm, powder coat it to match.
b) would my '79 CBX wheel even fit?
« Reply #42 on: November 20, 2015, 11:13:58 AM »
Can't say about the CBX stuff vs stock 75/76 F stuff but yes, you would need the 75/76 swing arm if everything else matches it and you prefer not to do the shock mount if you want to do it correctly IMO.
Keep in mind the 77/78 rear sprocket carrier is 10mm wide than the 75/76 so you need to determine which you have.
Make sure which engine/output shaft you have. Flush or offset?
My rear is not back together yet so I MAY be able to help with measurements once I'm home and have picked up my stuff from the coater late next week.
Offline riffman12
« Reply #43 on: November 20, 2015, 11:31:17 AM »
Thanks again, Jerry. I owe you big time once this is all done.
The annoying thing is that for some reason they put 5 rubber bushings in the rear wheel drive of the CBX, vs 4 in the CB750, so I can't put a narrower sprocket carrier :(
edit: this is what the CBX carrier looks like:
I wonder if it's possible to machine it down or something...
« Last Edit: November 20, 2015, 11:33:59 AM by riffman12 »
« Reply #44 on: November 20, 2015, 12:51:36 PM »
Naw, wouldn't even consider modding it like that.
The question is - do you need a different sprocket carrier? You really need both 750 rear set ups to compare to/with that one for total width and spacers.
Offline riffman12
« Reply #45 on: November 20, 2015, 01:56:19 PM »
changing the front sprocket carrier would really be just so I don't need to have an offset front sprocket.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #46 on: November 20, 2015, 02:01:35 PM »
Front sprocket carrier? You mean the output shaft?  ???
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline riffman12
« Reply #47 on: November 20, 2015, 02:24:02 PM »
no, this:
is that not what it's called?
« Reply #48 on: November 20, 2015, 03:26:57 PM »
 Rear sprocket is carried on that.  ;) Front sprocket fits on the output shaft.
Offline riffman12
« Reply #49 on: December 03, 2015, 09:26:44 AM »
so I'm trying a slightly different solution to fix my chain line...
my wheel has a 5 stud rear sprocket so I can't use an earlier 4 stud sprocket carrier.
BUT I found that the '82 - '86 CB450SC uses a skinnier 5 stud carrier. Pic of it on the left:
Ordered one off ebay...wish me luck
