OK so this rear wheel is going to fight me every step of the way.
![Angry >:(](http://forums.sohc4.net/Smileys/default/angry.gif)
So first I had some issues with the wheel bearings. I was tapping in the brake rotor side (the one with the retainer) and tapped it a bit too far so that it smushed up against the collar on the inside. After a lot of swearing I got it to back out a bit until it was just snug up to the collar, but could still move the collar.
![](http://i.imgur.com/H5rsaKQ.jpg?1)
but now I have a whole new issue. My brake caliper bracket is rubbing against my brake rotor. The spacing in the rear axle is wrong somewhere. See pics:
![](http://i.imgur.com/m648eoW.jpg?1)
![](http://i.imgur.com/vsDtvyU.jpg?1)
Here's the rest of what is going on, in case someone can see something that does not look right
![](http://i.imgur.com/uQRpv9J.jpg?1)
![](http://i.imgur.com/LjBMKIw.jpg?1)
![](http://i.imgur.com/jU19Pzi.jpg?1)
As you can see it is nowhere near centered in the bracket. I'm trying to figure out where the spacing can possibly be off. Here's my thinking so far:
1) I am using a wheel from a '79 CBX, but everything else here (axle, spacers, brake bracket) are from a '77 750F.
2) I double checked that the brake bracket was the correct fit, and indeed the CBX and 750F brackets are identical (same part number)
3) I' wondering if perhaps the two little collar / spacers on either side of the wheel were spaced different for the CBX. The part numbers are different.
4) I wondered if perhaps the little spacer / collar is not far in enough, but it pushes up against the bearing, and the bearing has no more room to go in.
I figured that all the Comstars would share the same spacing for everything regardless of bike model. Am I wrong in thinking that?
Here's how it looks on the bike...one day when I stop hitting road blocks like this
![](http://i.imgur.com/9e7YZcn.jpg?1)
I know it's a bit of a unique issue, but can anyone shed some light on this?
My next step might be buying a full rear axle from a CBX... but I'm worried it won't fit in the 750 swingarm or something silly.
