Author Topic: all balls neck bearings/ 77 cb400F Any tips?  (Read 613 times)
« on: October 11, 2015, 09:17:51 PM »
 The title says it all, I've done 750's I assume it's the same deal but it never hurts to ask an expert. I have the old races removed but haven't opened the all balls yet.
Re: all balls neck bearings/ 77 cb400F Any tips?
« Reply #1 on: October 12, 2015, 07:38:56 PM »
  I got it done, it's just like the 750's, the same part number and everything. I used the thin washer, I wish there was a thinner one, it left about 4 threads above the top bearing for the spanner nut. With no spacer it appeared the stops would rub.  Somehow I broke the hi/low beam switch button dangit.
Offline Powderman
« Reply #2 on: October 12, 2015, 09:02:51 PM »
I had to use a thick spacer under the lower race, could have been thicker. Other than that it was straight forward swap to mount a 90 CBR600f front end on my 77 400f.
« Reply #3 on: October 12, 2015, 09:14:26 PM »
Cool, the Hot Rod cb400F thanks you.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #4 on: October 12, 2015, 09:24:02 PM »
I also needed the thick spacer.
I have a motorcycle problem.
