Author Topic: my henry abe pistons and cyls compression Q  (Read 5083 times)
Re: my henry abe pistons and cyls compression Q
« Reply #25 on: October 21, 2015, 02:57:40 am »
« Reply #26 on: October 21, 2015, 09:26:25 am »
Yes, that's it.
Don't have the dome height numbers.
Offline BPellerine
1978 CB 750K ard and webers
another anfob
Offline BPellerine
« Reply #29 on: October 21, 2015, 01:49:08 pm »
so no one has any idea what compression ratio the ha stuff is,instructions say they increase comp so got to rejet?bill
another anfob
Offline turboguzzi
« Reply #30 on: October 21, 2015, 03:03:37 pm »
just higher compression per se doesnt change flow characteristics, at least not much, shouldn't impact jetting (if it was good to begin with).
Did just a decking job on my xt600 supermoto, i.e. only compression was increased and at least in my case didnt need to touch jetting.
but if you are increasing displacement, not just compression, then flow speed through carbs will increase and jetting might have to change.
crazy price BTW, way out of my range....
Offline BPellerine
« Reply #31 on: October 21, 2015, 05:24:21 pm »
thanks turboguzzi,I am going from 61mm bore to 67mm bore with the stock combustion chambers,my pistons are flat top,so was just trying to get an idea of the compression increase,ie bigger bore into small combustion chamber,stock comp is 9.1 or thereabouts.bill
another anfob
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #32 on: October 24, 2015, 06:33:53 pm »
 ;D
So I have a NOS HA kit I plan to install over the winter. I also am removing a old set of HA pistons from a motor currently. These are the old and new for you to compare side by side. Definately interesting. Im going back In to check weight and size differences.
The flat style are stock compression the newer styler are 10.25:1
New kit appears to be lighter. With deep fly cuts.
« Last Edit: October 24, 2015, 06:42:49 pm by TreyAllen »
« Reply #33 on: October 24, 2015, 08:02:37 pm »
Trey, slide a piston pin halfway through each piston to compare the compression heights.
Offline BPellerine
« Reply #34 on: October 25, 2015, 04:35:00 pm »
yes trey that would be interesting to check height from pin,and yes your nos pistons are higher comp than mine,I was just trying to get an idea of what rise if any I would get/not get with the flat tops with std chambers ie bigger bore moving more air into them,it will not be much.bill
another anfob
« Reply #35 on: October 27, 2015, 02:55:50 pm »
Diameter of the older one?
Same as Bills or like mine that seems to be 0.5mm wider. 66.9mm at top, 67.45 around the skirt
Offline BPellerine
« Reply #36 on: December 06, 2015, 01:34:48 pm »
here are my pistons installed!lightly ported ko head going on top!bill
« Last Edit: December 06, 2015, 01:40:22 pm by BPellerine »
another anfob
« Reply #37 on: December 06, 2015, 04:56:39 pm »
Looks great Bill. It's downhill from here.
Offline BPellerine
« Reply #38 on: December 07, 2015, 01:32:23 pm »
ya jerry that is what I am thinking too,always worked with twins,putting the barrels on a four is a whole ah hem,other experience !!done by spring!billp
another anfob
