Author Topic: '77 CB750 K7 café - Here I go again  (Read 18463 times)
Offline Andy K
« on: October 13, 2015, 10:30:00 AM »
hello for all!
like to share my biggest project of all time. you can see more pics and some story about it on below link to my blog.
I supposed to make some renewal things but project actually explodes in hands and have ideas to make some kind of cafe racer or something
to admin: if this is wrong place to this. move this away from here..
« Last Edit: September 09, 2016, 11:51:09 AM by Andy K »
ex bikes:
Honda CBR 1100XX '98
Suzuki VL1500 Intruder LC '98
Suzuki GSX1300R Hayabusa '03
this is my version of Honda CB750 '77:
http://caferacer77.blogspot.fi/2015/10/tasta-lahdettiin.html?m=0
Re: '77 CB750
« Reply #1 on: October 13, 2015, 12:05:44 PM »
Andy,
Welcome to the forum.
It looks like you picked up a 1977 CB750K in decent shape, with a partial dual disc conversion.  Is it running?  Before undertaking a rebuild, it is a good idea to get you bike running safely and reliably and assess which systems need work to safely function.
Your post indicates that you want to take the project in a café racer direction.  Do you have specific things in mind?
Offline Andy K
Re: '77 CB750
« Reply #2 on: October 13, 2015, 12:50:57 PM »
First.. sorry about bad english. not using translator every time. If there miss letters or there's too much letters, words are wrong, laugh and try to get point what I'm trying to write..
so..
yep 1.. cross my mind that find somewhere brake caliber to right side and make brakes little bit better.
yep 2.. cafe racer in my mind but this time only outer side. I've done nothing tuning stuff to the engine, brakes or suspension. Everything is stock parts. Only renew worn parts, paint or polish and put back.
it was running bike but little knockin sound in left (1 and 2 cylinder) valves and oil leaking between cylinder and head like shown in pictures. I got head full of special ideas but I don't have money, time or enough tools (like welding machine, lathe or milling machine) to do  and I'm father of three so family comes first..
I bought couple of days ago racer style left switch assy (blinkers, horn, lights) and today mini speedometer.. No Idea are they fitting to this bike. wasn't so expensive so I didn't loose lot of money..
this is my style to do bike what looks good for me and I try to do things so far by my self than I can.
Next step is valve timing adjust, holder for tail light, try to lift engine back to frame and fired up before winter. I would say that this is version 1, because handlebar is going to change clip-ons, seat have to make thicker and rear shocks are going to change "fake öhlins"...Maybe(!)... The thing in this fall is fired up the engine and make sure that engine works better than last spring when this project started.
« Last Edit: October 13, 2015, 01:27:22 PM by Andy K »
ex bikes:
Re: '77 CB750
« Reply #3 on: October 13, 2015, 01:36:35 PM »
At a minimum, you will want to replace the leaking gaskets and adjust your valves. You may also take the chance to lap the valves and check the wear on the cylinders.  You should also do a compression test to see if the cylinders need to be bored and honed.
Offline Andy K
Re: '77 CB750
« Reply #4 on: October 13, 2015, 11:29:41 PM »
as you say.. done
in my blog you see that i've done all of that and only valve timing adjust is left to do. This post came later than project start but i'd like to share it here. Front shock absorbers was pieces and new parts are changed. Rear shocks need to check too.
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #5 on: October 13, 2015, 11:34:14 PM »
cylinders and pistons..
ex bikes:
Re: '77 CB750
« Reply #6 on: October 14, 2015, 06:04:27 AM »
Following
Offline Andy K
Re: '77 CB750
« Reply #7 on: October 14, 2015, 07:12:31 AM »
thanks..
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #8 on: October 20, 2015, 05:09:27 AM »
new muffler and handlebar
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #9 on: October 20, 2015, 05:12:26 AM »
brake caliber renewal:
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #10 on: October 20, 2015, 05:34:48 AM »
wondering what kind of shape is best to the tail. And testing new exhaust place..
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #11 on: October 20, 2015, 05:49:43 AM »
Finding tail model..
This was first idea. Cover boths sides of frame but it was way to wide..
My tools how I made the tail cover + my knee and hands
This was better
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #12 on: October 20, 2015, 05:53:25 AM »
..and finally.. I love it:
with tail light
The blinkers are without cover on this picture
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #13 on: October 20, 2015, 06:00:36 AM »
inner blacksmith.. making the seat
Thread rod come though of these brackets
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #14 on: October 20, 2015, 06:34:35 AM »
I trying to daily my blog at same time. There's some more pictures
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #15 on: October 21, 2015, 10:16:20 AM »
painted
ex bikes:
Re: '77 CB750
« Reply #16 on: October 21, 2015, 11:14:17 AM »
Re: '77 CB750
« Reply #17 on: October 21, 2015, 04:04:21 PM »
Yes, very well done!
Offline Andy K
Re: '77 CB750
« Reply #18 on: November 03, 2015, 11:32:21 AM »
fitting new parts..
« Last Edit: November 03, 2015, 12:53:20 PM by Andy K »
ex bikes:
Offline riffman12
Re: '77 CB750
« Reply #19 on: November 03, 2015, 12:11:00 PM »
engine looks great!
Offline Andy K
Re: '77 CB750
« Reply #20 on: November 03, 2015, 12:46:20 PM »
oops.. picture turns..
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #21 on: November 03, 2015, 12:48:02 PM »
new switch assy
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #22 on: November 03, 2015, 12:49:57 PM »
..and speedometer
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #23 on: November 12, 2015, 10:54:37 AM »
engine back in frame..
ex bikes:
Offline Andy K
Re: '77 CB750
« Reply #24 on: November 12, 2015, 10:56:50 AM »
oops again..
ex bikes:
