Author Topic: How's it sound so far?  (Read 1142 times)
Offline eoddom
« on: October 20, 2015, 07:30:42 AM »
So I got the bike running on all 4 cylinders finally.  I think the sound I'm hearing at idle is timing chain?  Also excuse the really crappy exhaust, it's some straight exhaust that someone at some point put on it and it's all rusted and probably leaking at the head.
Also having an issue with the idle taking a while to come back down but that's probably due to it needing a sync and messing with the IMS a bit.
Offline mrfish2
  • I might be a
Re: How's it sound so far?
« Reply #1 on: October 20, 2015, 08:29:34 AM »
Idle hanging up like that means you're lean sonewhere, time for some plug chops!
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline eoddom
« Reply #2 on: October 20, 2015, 08:44:32 AM »
Alright I'll have to look into how to do plug chops.  I just assumed since the carbs were rebuilt and only bench synced, that it may need a proper vacuum syncing.
Offline Mantree
« Reply #3 on: October 20, 2015, 01:00:24 PM »
It you are running lean it will knock badly that might be what you are hearing
Sent from my ME302KL using Tapatalk
Offline eoddom
« Reply #4 on: October 20, 2015, 02:47:54 PM »
Does it sound like a knock?
Offline enwri
  • So that noise is normal?
« Reply #5 on: October 20, 2015, 04:22:06 PM »
The exhaust is leaking, but it's still weak on one or more cylinders.
Those infra red thermometers can identify which exhausts are cooler and carbs that need attention, or need opening (sync)
syncing will even things out, but only if all the cylinders are running.
up to you to work out if it's the carb on any cylinder not opening enough (sync) or not running properly to start with, plugs, tappets, compression, flooding, starving, blocked. often some combination of all.
All at the same time.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline eoddom
« Reply #6 on: October 20, 2015, 06:07:56 PM »
Well I dropped the bowl for number 1 carb today, and the main jet was sitting in the bottom of it.  So that could cause problems...hahaha.  It's too late to fire up and check with a sleeping baby, but tomorrow is a new day.  New plugs and new plug caps.  Gonna adjust valves and check timing tomorrow
