Author Topic: CB 350 Four: Oil lamp lights 5 seconds after engine turn off  (Read 2013 times)
thomas evensen
I have done a complete rebuild of my CB 350 Four engine and carbs, and it runs fine :)
The oil lamp goes off just as the engine starts. When I turn the engine off, the light
allways use about 5 seconds before it lights on. I believe this is because the oil pressure
is not released momentarily.
Thanks!
greetings,
Thomas Evensen
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: CB 350 Four: Oil lamp lights 5 seconds after engine turn off
« Reply #1 on: May 28, 2005, 01:08:37 PM »
Is this a question or a statement?
Oil light staying off for 5 seconds is good. It means the pressure is leaking away slowly.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
don_m
« Reply #2 on: May 28, 2005, 02:48:54 PM »
If the oil lamp is staying on after you turn off   the engine, than you must be using the ignition cut-off switch on the R/H control assy.  The switch is made for emergency use, not frequent, and will fail if used much.  The control switches are scarce, expinsive & difficult to replace as the wiring goes inside the handlebar.  You   have been warned!
Cheers, Don Psycle Madden.
thomas evensen
« Reply #3 on: May 29, 2005, 12:26:51 AM »
Thanks. I am turning the ignition off and on - I am not useing the cut-off switch :)
Thomas
