Author Topic: Cb360 to 350 charging system swap?  (Read 607 times)
Offline larrydallas
« on: October 21, 2015, 05:28:10 PM »
hi
Can I swap the charging system from the 360 to 350?  I cant think of a reason why not, but I do know that the engines are basically completely different, so I'm not too sure.
I've read that the axle bolt will thread into the rotor to remove it if you don't have a puller, but it's on there real good.  Is there a trick to get it off?
Cheers
