There is a ignition upgrade for the Cb650 but it is a diy deal I will see if my buddy can explain it to me but he has a much hotter spark as fore the rest of it get a wire rack and some split loom find a wiring diagram and get to work up read your fuse block, reg and rectifier use the same starter solenoid we left you are at it add a relay to take load off the ignition switch and upgrade to a electronic turn signal flasher then you can run led lights and take load off the system
Sent from my ME302KL using Tapatalk
