Author Topic: APE Ultra cranks  (Read 1585 times)
Offline Big Jay
    • CBRzone
APE Ultra cranks
« on: October 25, 2015, 06:06:27 PM »
APE Honda 750 sohc Ultra crank.
Top photo, finished crank, lightened, rod journal oil holes modded for more oil at the bearing, and dynamically race balanced to less than 1/3 gram. This is APE ‪#‎LC750‬
Bottom, same crank with Carrillo H beam rods installed, ready for the customer to drop into his cases. This is APE part ‪#‎ULCKH750‬. http://cbrzone.com/sohc.html
Visit APE Racecranks.com http://www.racecranks.com/
Offline gschuld
Re: APE Ultra cranks
« Reply #1 on: October 25, 2015, 07:49:29 PM »
Nice Jay.  I may have just seen that setup at MRieck's place not long ago.
George
Offline Cpcracing
  • CPCRacing
    • Cutler's Performance Center
« Reply #2 on: October 25, 2015, 09:48:45 PM »
Thanks for sharing the photo. I have one on order from you exactly like your bottom photo.  I can't wait to get mine!!
1974 & 75 CB 750K
« Reply #3 on: October 26, 2015, 02:33:01 PM »
Quicker to red line, pass it and stay there without worries thanks to Ultra crank with Carillos :)
I'll try that next season.
Offline Tintop
« Reply #4 on: October 26, 2015, 04:18:05 PM »
metal porn  8) 8) 8) 8) 8)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Online MRieck
« Reply #5 on: October 27, 2015, 05:32:15 AM »
George
You did George except bought the rods from Jay and installed them here. The part is for an overseas customer. ;)
Offline gschuld
« Reply #6 on: October 27, 2015, 11:41:38 AM »
Mike,
I know you prefer old RC golden rods to anything else though.  :P .... ::)
George
« Reply #7 on: October 27, 2015, 02:51:11 PM »
The crank-rod setup look almost too good to hide between the crank cases! :)
« Reply #8 on: November 13, 2015, 10:42:09 AM »
Funny, I have got a reason to time my cam a little bit later for more fun after 9000rpms!
1-2 degrees later might do just a little.
Offline BPellerine
« Reply #9 on: November 13, 2015, 01:59:56 PM »
is that your crank pewe,nice!
1978 CB 750K ard and webers
another anfob
« Reply #10 on: November 13, 2015, 02:31:40 PM »
Yes, I understood I must have one since I got a tachometer again and saw the needle passing the red very often. I was waiting for a rod failure.
The rod in 4:th got its small end hitting the case when assemble the engine 30 years ago. I had to leave it for a hone to be able to fit the piston pin. I have since then had thoughts about that when driving fast.  Piece in mind and quicker responce.
I'll upgrade some when open cases again.
Offline BPellerine
« Reply #11 on: November 13, 2015, 06:47:56 PM »
maybe a bigger engine?
another anfob
« Reply #12 on: November 15, 2015, 02:11:17 AM »
I have those thoughts too.... :) It will cost some...
How my 836 pistons and bores will look when taking it apart will help my decision.. Mikes block with 72mm pistons would be great!
I'll send a low mile primary drive to Germany for rubber upgrade. I have reinforced primary chains since before so the engine is ready for more. :)
