Author Topic: Samauto II RC1080cc, RC crank and Golden rods, 327 cam etc, CB750 Automatic  (Read 56937 times)
Offline jweeks
Re: Samauto II RC1080cc, RC crank and Golden rods, 327 cam etc, CB750 Automatic
« Reply #25 on: November 07, 2015, 11:27:44 AM »
With a drag chassis, there were no provisions for rear shocks. Haven't had any problems with good tracks. It was built as a bracket bike, not low ET of the earth type.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #26 on: November 07, 2015, 01:06:19 PM »
I've tried that rear brake setup. I'm up to high 11's estimated best using it. I suspect that the bike will pull through the rear brake pressure with the right cam and converter. This is sounding more and more like a slow off the line, top end strong bike. Good luck with this one. You definitely need some test and tune time to sort out the launch. I just hope that the fiber clutches are mostly there. If they are badly worn, you'll find a slipping clutch on launch and/or at the gear shift. Good luck!
Jon, I hear you...but I ain't telling all,,ok how about using f brake also, with micro switch on brake lever controlling line lock,  release both brakes same time! I think it might just work! I'm back at it, got some news on 2K bonus also, see other thread in a little whilel pics in a minute, as usual, any advice welcome, ideas etc.Bill
« Last Edit: November 07, 2015, 01:12:46 PM by Bill/BentON Racing »
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #27 on: November 07, 2015, 04:34:32 PM »
Rear brake rebuild,  Bill  ;D
Offline dragracer
  • CB750F Dragbike
« Reply #28 on: November 07, 2015, 06:25:04 PM »
Keep it moving Bill. You're getting it done by your own vision. No stop when the brake rebuilding is done and crank it up. You still don't know what you're working with motor and carb wise. It'd be a shame to go through all that work just to find out you needed to have spent time adjusting valves or rejetting the carbs. Worst yet, the  proposed onboard start system won't work with one battery trying to crank that high compression 1080. No many days left brother. Make them count. I've got confidence in you.
Offline edwardmorris
  • Youngish
« Reply #29 on: November 07, 2015, 08:56:58 PM »
Bill, that vid finally plays!
Quick sidetrack, anyone hear from Sammy Green lately? Been trying to get a hold of him but no luck.....
Offline BPellerine
« Reply #30 on: November 08, 2015, 05:16:13 PM »
Rear wheel
unreal bill,never seen one go that long!+1 on warren and the boys!billp
1978 CB 750K ard and webers
another anfob
Offline POPS 911
« Reply #31 on: November 09, 2015, 11:08:28 AM »
1080ccc no way that Matic not going in the 10's , GOOD LUCK BILL on the first CB750A HONDAMATIC in the 10's at a MAN CUP RACE.
    • BentON Racing
« Reply #32 on: November 09, 2015, 01:49:44 PM »
POP'S,  thanks, but I got a long way to go.....and a short time to get there!  ;D, Bill I did just fix this and turn it over...goes boom boom boom!
    • BentON Racing
« Reply #33 on: November 09, 2015, 01:53:58 PM »
I'm on to plug wires,  then battery, then we check and change oil,set valves, new plugs etc, crank tonight or tomorrow. ;D
Offline dragracer
  • CB750F Dragbike
« Reply #34 on: November 09, 2015, 02:25:25 PM »
Please use caution starting the bike with that Bill. I have personally witnessed an outboard starter break several arms and wrists. Grip it tightly when using and don't put your head low enough for the handles to crack your skull in case it slips.
    • BentON Racing
« Reply #35 on: November 09, 2015, 02:43:25 PM »
I'll never forget my first time on Fletcher's bike, I didn't know to have the bar on engine case! I have not forgotten, at least I cranked his bike and then untwisted my pretzel arms as the little toy brain said what's wrong with this picture! LMAO. Thanks,  Frank, I appreciate the reminder.
  • Moderator
« Reply #36 on: November 09, 2015, 03:10:30 PM »
You only make that mistake once Billy, hahahha.
Good luck all at Valdosta.
Sam. ;)
Offline Fastbike
« Reply #37 on: November 09, 2015, 06:37:20 PM »
Hey Bill, I forgot about that!  It did tie you up in a knot :o.  Thanks for the help!  24Volts can mess you up ::).
I'm not as smart as I look, but I am pretty.
Offline Fastbike
« Reply #38 on: November 09, 2015, 06:40:04 PM »
Oh yeah,  HI SAM!  Hope you're getting better every day.  Everybody would love to see you ;).
« Reply #39 on: November 09, 2015, 09:17:54 PM »
Yeah, that was pretty funny  ;D
I'm down the road if you need a hand. I got in but my bag did not.
    • BentON Racing
« Reply #40 on: November 09, 2015, 11:41:01 PM »
Yes it was. 1080 engine has an internal engine problem.  It binds up at one point and something is hitting something!
Time to concentrate on Cobra Girl!  I'll fix the Automatic asap once I get back from Valdosta,  Bill
  • Moderator
« Reply #41 on: November 10, 2015, 01:23:58 AM »
I would love to see ya'll to Dave but it's not going to happen, not soon anyway.
As you all sleep, I'm waiting for a cab to take me to the hospital to see the big consultant Neuro Dr that has been overseeing my rehab. I think it's only a routine check up as I've not seen him for 6 months. I'm not sure if he will give me the all clear (or this is as good as it gets) as I am no different to when he last saw me.
Good luck at Valdosta Dave and everyone, ride safe.
Sam. ;)
Offline POPS 911
« Reply #42 on: November 10, 2015, 06:26:13 AM »
HONDAMATIC down for the count again ????  Had a GS motor that when we turn over BY HAND stopped and locked either way rolling motor over, pulled the motor down and found a valve keeper stuck in the crank gear......... how and why it got their was never found. That is why Joe MSP built a motor room and only two people at a time was allowed in that room, motors only, no eating, no folks standing around, and a super clean work station. Try this when you are ready to fire up the MATIC = SPIN THE MOTOR OVER WITH NO IGNITION ON AND AT A SIGNAL FROM THE RIDER FLIP THE ON SWITCH TO SAVE THAT CRANK [ rings have not moved in the whole trip getting to the track ], Pro Stock motors are started that way so the crank and motor live a little longer = PRO MOTORS riders turn on vacuum pump first, then spin, then switch ON START.
Bill wire in a two step, no creeping then, all those BUSA in ST/ET sound up and down with their clutch in and rider rolling on the gas = WATCH AND LISTEN!!!!
Offline TurboD
« Reply #43 on: November 10, 2015, 06:38:43 AM »
Bill How were you able to rotate the engine over to set the valves?
« Last Edit: November 10, 2015, 07:34:52 AM by TurboD »
Offline dragracer
  • CB750F Dragbike
« Reply #44 on: November 10, 2015, 08:04:41 AM »
My guess is he discovered it wouldn't easily rotate over when he was attempting to set the valves.
« Last Edit: November 10, 2015, 10:26:41 AM by dragracer »
« Reply #45 on: November 10, 2015, 08:06:33 AM »
dammit! cam too big?
    • BentON Racing
« Reply #46 on: November 10, 2015, 11:39:34 AM »
Give that man a gold star! I'm guessing too tight sumpin, and a valve hitting/ bent.We'll find out l why later.
    • BentON Racing
« Reply #47 on: November 10, 2015, 11:40:22 AM »
 :'( ;D
Offline dragracer
  • CB750F Dragbike
« Reply #48 on: November 10, 2015, 12:55:33 PM »
:'( ;D
I hate you went to all that work converting it BEFORE you checked the motor over. At least now its only motor work left to do. Looks good by the way.
Offline BPellerine
another anfob
