Author Topic: Newbie building a wheel, help me figure out hub offsets  (Read 1703 times)
Offline zoogler
« on: November 06, 2015, 08:26:44 AM »
Hey everyone,
I'm working on building wheels for my '77 cb400f project.  I've built/trued the front wheel, with a lot of help from the posts in this forum.
Now, for the rear wheel.  After re-reading some of the threads here, I've learned that the rear hub may not be centered over the rim.  Of course, I took the wheel apart before measuring any potential offset.  Oops.
A couple questions:
1) I've read a ton of posts about wheel building, but I don't see a consensus on if the offset should be created by adjusting for it in the truing process, or just centering the hub and then using spacers.  There are posts advocating for each method.  I'd prefer NOT to fiddle with the offset while truing -- dealing with the vertical/horizontal truing is difficult enough!  Can I just center the hub and use spacers?
2) If the answer is "no", does anyone know the correct offset with stock rims/hubs for a '77 cb400f? My frame is at the powdercoater, so I can't do the "straightedge" trick mentioned in other threads to measure it (centering the wheels first in the frame to find the offset)
thanks again for all the great info posted here.
Offline Powderman
Re: Newbie building a wheel, help me figure out hub offsets
« Reply #1 on: November 06, 2015, 09:23:20 AM »
I just measured my 77 CB400f wheel and the hub is centered on the rim. Mount it on the bike and line up your sprockets and then decide what spacing you need. If you have all the proper stock parts everything should line up. If not, something is bent or you have the wrong spacers.
Can anyone name a model of bike where the rim is intentionally offset from the hub? I don't know of any Honda's built that way, or a reason it would be done.
« Last Edit: November 06, 2015, 09:27:05 AM by Powderman »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: November 06, 2015, 09:38:12 AM »
Usually no offset on these bikes although the 400F I'm not positive.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Bodi
« Reply #3 on: November 06, 2015, 09:41:20 AM »
I have built several 400F wheels and the hubs have zero offset.
Offline Powderman
« Reply #4 on: November 06, 2015, 09:41:36 AM »
Mine is original and centered, not offset.
Offline zoogler
« Reply #5 on: November 06, 2015, 09:55:39 AM »
Well, that's easy.
I did see a few posts about cb400fs where they mentioned the hubs being offset, which had me worried.  Ex: http://www.dotheton.com/forum/index.php?topic=38849.0
thanks!
Offline Powderman
« Reply #6 on: November 06, 2015, 10:09:12 AM »
Well, that's easy.
thanks!
I would completely ignore that thread. That's guy who had issues with spoke length, not offset, after replacing new rims . His original didn't have any offset, and he didn't mention that it did afterwards.
Offline Jinglyjangly
    • jinglyjangly images
« Reply #7 on: November 07, 2015, 07:53:05 PM »
From what I've seen Japanese bikes are properly engineered and don't need the
Wheels offset, on the other hand all my British bikes do need offset.
2 x cb350-four honda 500-4 race bike
rickman cb750 1 x rc163 replica, 2 x cbr250r yamaha tzr250 yamaha tz350
yamaha trx850 yamaha rd500 suzuki gt250 suzuki gt500 plus Norton's, Triumphs,Velocette's and BSA's
Plus bunch of Brits, Velo's, Triumphs Norton, AJS and others
Offline przjohn
« Reply #8 on: November 09, 2015, 09:10:05 AM »
Same here, bikes with conical hubs on vintage dirt bikes too. I did a 74 CanAm 250 restoration and the manual was pretty detailed on setting the offset of the conical hubs. The 400F I did last Winter had no offset.
