Author Topic: "Mile High" CB350 Four project  (Read 32523 times)
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: "Mile High" CB350 Four project
« Reply #175 on: July 15, 2017, 07:46:47 AM »
Looking great so far!!
Thanks Pale!  BTW that tank and tail may be headed your way at some point.
It would be my pleasure.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #176 on: July 15, 2017, 08:01:33 AM »
Good to know, wish I knew before!  Gotta make mistakes to learn from them I guess...
There is one other bit of subtlety that they do NOT address. At the end of the project, when the new bearings and spacer are installed it is common to end up with a slightly larger overall distance between the top bridge and the triple clamp. Not an issue with a bike like yours that isn't using headlight ears, but on 500s and 550s and others that have ears between the triple and bridge, Honda uses rubber grommets above and below the ears to firmly anchor the ears with compression so they do not rattle.
There are two ways to remedy that: One is to machine the top bearing nut (under the bridge) so the top bridge can sit lower, and the other is to simply add an oring above or below the ear-and-grommet stack before installing the top bridge.
I have a motorcycle problem.
Offline Denver_Larry
« Reply #177 on: July 15, 2017, 03:06:52 PM »
Thanks for the tips guys.  Disassembled, re-polished, added spacers, reassembled: all good!
2005 RC51
1973 CB350F...project
Offline NobleHops
« Reply #178 on: July 15, 2017, 03:47:14 PM »
ROLLER!!!
 ;D ;D ;D
Nice milestone Larry!
Offline calj737
  • I refuse...
« Reply #179 on: July 16, 2017, 04:28:46 AM »
ROLLER!!!
Head turner!
 ;D ;D ;D
Fixed that for you, Nils  :D
« Reply #180 on: July 17, 2017, 09:16:48 AM »
Thanks, I appreciate it guys.  It's nice to see it coming together!
2005 RC51
Offline NobleHops
« Reply #181 on: July 19, 2017, 10:11:22 AM »
ROLLER!!!
Head turner!
 ;D ;D ;D
Definitely better now :-). Thanks Cal.
Offline palepainter
« Reply #182 on: July 23, 2017, 08:35:18 PM »
Looking great.  I was curious as to who you used to powdercoat frame if it is coated?
« Reply #183 on: July 23, 2017, 08:47:04 PM »
ColorWerks
Price isn't too bad other that the $100 minimum.
2005 RC51
« Reply #184 on: August 03, 2017, 07:51:58 PM »
A couple questions about the coil mounts:
1.  I'm assuming that I need to strip the powdercoat down to bare metal between the mounts and the frame to ground them, but I want to make sure.
2.  Is dielectric grease (or something else) used anywhere here as a best practice?
2005 RC51
Offline innovativems
    • Innovative MotoSports
« Reply #185 on: August 04, 2017, 08:58:18 AM »
it's looking amazing!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #186 on: August 04, 2017, 09:46:17 PM »
Never mind on the coil/ground questions... evidently there is no need!
Sent from my iPad using Tapatalk
2005 RC51
« Reply #187 on: August 04, 2017, 09:47:29 PM »
Thanks inno!
2005 RC51
« Reply #188 on: August 09, 2017, 12:57:06 PM »
Alright, I'm trying to get to the bottom of the gearing thing...
I want to at least start with the OEM sprocket setup, but I can't seem to nail down what the stock gearing was.  Most of the aftermarket gearing manufacturers list the stock gearing as 16/38, but I've also seen 16/36 and 17/38.  17/38 is what I think is right, primarily since the manual lists a gear ratio that matches exactly what a 17/38 has.  Can anyone shed some real light on this?
2005 RC51
Offline markreimer
« Reply #189 on: August 10, 2017, 03:03:15 PM »
This is absolutely gorgeous! Can't wait to hear it! Did you do anything specific to address the common 350F oil leak along those oil orifices outside 1/4? What brand gaskets did you use? I rebuilt a 350F over winter and I'm opening it up again tonight to diagnose a major oil leak into #1.
« Reply #190 on: August 10, 2017, 03:15:47 PM »
Combo of NE brand and OEM gaskets.  Around the orifices I just gave it a very thin coat of the high temp hondabond.   Just be careful not to be sloppy since any that gets in the orifice will likely plug it eventually and starve the top end.
2005 RC51
Offline markreimer
« Reply #191 on: August 10, 2017, 03:34:15 PM »
I did the same thing. Very light film on the rubber seal exterior. Copper coat on a OEM head gasket. What kind of head gasket did you use? Bike looks siiiick!!!!
« Reply #192 on: August 10, 2017, 03:48:52 PM »
Thanks Mark, going slow but steady....
Honestly can't remember if the head gasket was one of the OEM ones or not (But I THINK it was).  I didn't apply the hondabond to the rubber seal itself, just a thin coat on the mating surfaces around them.
2005 RC51
« Reply #193 on: August 23, 2017, 05:37:16 PM »
Help!
Finally got my sprockets in, and I'm having clearance issues.  My primary clearance issue is with the chain passing the shock.  I had axle spacers installed on the wrong sides I think to start, but can anyone confirm which side gets the bigger spacer on a CB350F?  I moved the bigger spacer to the left side which helped some, but it's still not quite right.  What is right is my chain line seems perfect.  I'm running a 520 conversion which effectively removes thickness from the left side of the drivetrain which theoretically should help with clearance.
2005 RC51
« Reply #194 on: August 23, 2017, 05:38:37 PM »
And since I swapped spacers, my tire is now rubbing on the brake stay.  I don't want to re-true the wheel to fix that until I'm sure about the spacers.
2005 RC51
« Reply #195 on: August 23, 2017, 05:42:18 PM »
2005 RC51
« Reply #196 on: August 23, 2017, 05:52:01 PM »
Large spacer goes on the drum side.  Are you running a 520 o ring?   Looks like it.  Should clear.  I'm running 520 o ring and race tech shocks with no issue.   But I also am running a Framecrafters swingarm would is probably alittle wider in the back
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #197 on: August 23, 2017, 06:15:26 PM »
Shoot.  Big spacer on the drum side makes things worse.  How big is your rear sprocket?  I'm running a stock size (38).
2005 RC51
« Reply #198 on: August 23, 2017, 06:33:46 PM »
Swapped the big spacer back to the right side.  Fixed the brake stay clearance issue (only have 1mm: yikes!), but the shock clearance issue is significant.
I figure that I can gain about 5mm clearance if I machine the inside of the clevis and add more washers to the one that's already there, but am I missing something obvious?  I would rather not start machining on $1000 shocks if I don't have to...
2005 RC51
« Reply #199 on: August 23, 2017, 06:44:10 PM »
Had a brainstorm:  if I run the preload collars up the shocks, I could have spacers made for the bottom spring perches that would get the perch moved straight up about 15mm and I think that would do it.
2005 RC51
