Author Topic: Will checking exhaust header temperature help to tune???  (Read 1340 times)
liaudio
« on: November 03, 2006, 06:23:56 AM »
I have an infrared thermometer and decided to check the temperature of each cylinder via the exhaust header.  I did this before I synched the carbs and before I got a Dyna.  I saw about a 25-40 degree difference between 1 and 4 versus 2 and 3.
Would this be a practical way to tune the bikes stochiometric ratio?
Offline crazypj
  • I'm brill, me
Re: Will checking exhaust header temperature help to tune???
« Reply #1 on: November 03, 2006, 09:07:41 AM »
2&3 will always be slightly hotter than 1&4. You can get rough estimates of problems with infra red thermometer though. We use them to check for running conditions on multi cyl quite a lot.
PJ
Offline eurban
« Reply #2 on: November 03, 2006, 05:53:33 PM »
Keep in mind that if your headers are chrome that the ir thermometer won't give anything close to an accurate reading.
Offline kghost
« Reply #3 on: November 03, 2006, 09:03:01 PM »
Yes and no.....
Unless you know the precise temp produced by the desired air/fuel ratio on your engine.
Otherwise all you get is a comparison of the cylinders and an idea if your getting richer (colder) or leaner (hotter) unless you get way lean (then it gets colder again)
Stranger in a strange land
