The SOHC/4 World Tour is in under way.
Same here, better to replace it than fix it.
Ah so! Now it makes sense. I had this vision of broken fork, brass welded together.
but if i have TIG or MIG welded that fork it could be harder but forks wear out faster because heat makes more harder and more breakable like strynboe said. maybe brass isnt so hard like steel but its more sturdy.and if forks ran out of brass i still can use forks because they are still in the specs. but i can maybe get used forks if i could find them.
