Author Topic: CB550 Brake Pedal to Pivot/Arm Orientation  (Read 730 times)
Offline 67Fastbackfan
« on: November 14, 2015, 08:38:52 AM »
Rebuilding my '75 CB550 from the ground up so I have nothing to compare to.  Previous owner did not have correct parts on the bike, so, I'm trying to make sure I have the correct orientation for the brake pedal to where it mounts to the pivot arm.  Is it just a 45 degree? So if the pedal is in its correct spot for my comfort the pivot arm is pointing at the 6 o'clock position or is there a certain angle I should be adjusting for?
I looked in my shop manual but saw nothing that specific.
Any pictures of your bikes brake pedal set up would help a lot!
Thanks in advance
Offline mrfish2
  • I might be a
Re: CB550 Brake Pedal to Pivot/Arm Orientation
« Reply #1 on: November 14, 2015, 10:07:40 AM »
I'm on my phone and don't have the link saved, but search for Sohron's build thread. He's got a lot of good quality photos showing everything about putting a 550 back together.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline MandEms
  • MandEms
« Reply #2 on: November 14, 2015, 02:01:27 PM »
From my 76 550 F
Mark
Offline MandEms
  • MandEms
« Reply #3 on: November 14, 2015, 02:02:13 PM »
Also from my 76 550F
Mark
Offline MandEms
  • MandEms
« Reply #4 on: November 14, 2015, 02:04:09 PM »
Mark
Offline MandEms
  • MandEms
« Reply #5 on: November 14, 2015, 02:04:57 PM »
Mark
« Reply #6 on: November 14, 2015, 04:54:14 PM »
Thanks for the help and pictures. I realized I was going about it backwards. Instead of installing the pedal last, I was going to do it first. Took a break for a while and and realized it's easier to line it up by mounting everything to the assembly first.
Offline CBDee
« Reply #7 on: November 16, 2015, 12:19:16 PM »
Here you go
http://forums.sohc4.net/index.php/topic,151576.msg1731565.html#msg1731565
This guy shows exactly how it goes. There's more to it then is obvious, so I'd recommend giving it a,look.
Sent from my Old & Busted PC using Myindexfingers
