Author Topic: Plug chop for dummies?  (Read 9847 times)
Re: Plug chop for dummies?
« Reply #25 on: January 06, 2016, 07:21:27 AM »
I guess i'm lucky.
Highway 9 is in my backyard and I have a 10 mile stretch with only 3 stoplights...and only 2 miles of it is flat  ;D
As I mentioned above, most riding probably isnt done at WOT, so 'close' main jet is fine.  Plugs just shouldnt be lean/white here.
For the vacuum sync, what type of unit are you using, and has it been calibrated recently?
Vac sync should be done at the lowest possible, non-laborious idle your bike can handle.
Mine is ~1100rpm, and yes, my gauges show different vacuum across the gauges if the throttle is held open.
Offline flatlander
« Reply #26 on: January 06, 2016, 07:32:57 AM »
Would also love some more input on how else I can determine proper jetting that doesn't require hauling ass at redline down windy, hilly roads for a few miles.  ;D
you can find out where, in your area, there's a shop with a dynamometer (dyno). best would be one that's familiar with our type of bikes and has a good reputation.
you can do runs on the dyno instead of the road and a sniffer in the exhaust measures air/fuel ratio instead of reading plugs. plug chops are cheaper (as long as you don't get a ticket or hit something) but the dyno can save you a lot of time and nerves.
as a side-benefit it can also measure power output on your rear wheel if you're interested.
i've done plug chops and got to fine settings with them, they work. but since i found a good dyno guy who doesn't charge too much, i just go there.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #27 on: January 06, 2016, 09:05:53 AM »
Personally I would just ride it as much as possible for a couple of weeks and then see what your plugs look like. If they are still lean then maybe you have too much air coming into the system? Maybe a vac leak or you need to restrict the intake?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline SamP
« Reply #28 on: January 06, 2016, 12:09:24 PM »
This is my vacuum synch tool. Yes, restrictors are installed. Syncing at about 1000-1100.
Sent from my LG-H811 using Tapatalk
