Author Topic: 550 triple on 750  (Read 1510 times)
whodareswins
550 triple on 750
« on: November 03, 2006, 07:03:05 PM »
Can you run a 550 triple and forks on a 750?
Offline kghost
Re: 550 triple on 750
« Reply #1 on: November 03, 2006, 09:04:45 PM »
Why would you want to?
Stranger in a strange land
whodareswins
« Reply #2 on: November 03, 2006, 09:29:01 PM »
because I dont have a 750 triple on hand but have two 550 triples and it looks pretty much the same. by hte wa yif this helps the 750 is a 73 and I  also want to put comstar wheels on it because that is what I have.I have also read on the forum that there are problems mounting those wheels anywayThe front wheel is 100/90/19.HOpe some one can help.
Frank
Offline kghost
« Reply #3 on: November 03, 2006, 09:44:31 PM »
I seem to recall the 500/550 forks being a tad shorter and thinner.
That being the case I would say they make a bad choice for the 750 weight wise and would be bound to affect stability / handling.
The comstars can be made to fit on a K frame but its a matter of spacing and brake disc. The comstars have a 5 hole brake disc mount while the spoked have a 6 hole rotor mount.
The offset on the rotors are different between the two as well.
I got around that with my Frankenbike project (which uses a K frame) by using the complete front end off of an F model 750
Pic's here:
http://www.sohc4.us/gallery/v/members/personal/kghost/Frankenbike/
« Reply #4 on: November 04, 2006, 06:45:29 AM »
Yokes (trees) used as a pair will be ok as the forks are the same diameter, not sure aboout the rake--thats why i said a pair. Comstars only if you take a complete front end as rotors are different fitting and thickness and therefore calipers mounted different etc, etc
Offline cafe75-550
« Reply #5 on: November 04, 2006, 09:58:28 AM »
I believe the 550 forks are a little shorter, so it may lower the front end a bit, haven't heard about them being thinner, they are the same OD, 35mm. But the 550 forks won't be sprung or damped for the heavier 750, so your suspension response won't be the same either.
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
