Hmmmm. That seems to make sense. The engine and carbs should be good unless something failed, but nothing seems to indicate that. The top end was just rebuilt, and carbs thoroughly cleaned. Air should be good, I have new rubber boots on the original airbox, with a foam filter replacement for the old paper filter. Everything was running perfectly until last weekend, when it was a little reluctant to start, which I thought was just the cold. Yesterday it turned over once and then quit, now I can't get it to go.
I put new plugs in today and still couldn't get it to turn over. The old plugs were carbon fouled, but not terribly. It did seem the 1-4 spark was stronger than the 2-3 spark. Also i noticed that I get a few promising kicks before i just get no response. Wait a few minutes and the same thing, few sputters, then unresponsive.
The plug wires have always been a bit suspect. 1-4 seem original, but at some point some part of 2-3 seems to have been replaced, probably the coil. The plug wires are spliced in to the coil wires rather than continuous to the coil. The sheathing on one of those spliced wires is pretty deteriorated, all gooey.
I think what i'm going to do is something I've wanted to for a while, swap in an electronic ignition with new coils and wires. After having to rebuild the top end this summer, the maintenance/riding ratio is skewed in a way that is testing my patience this season, and it just seems easier.
The condensers were swapped out a year ago just as part of points servicing. Two years ago the old rectifier was bad and was swapped for an oregonmotorsports rectifier. Because of new lower profile turn signals installed this season, the entire wiring harness was checked out, all connections pulled, sanded, dielectric greased, and reconnected. The clutch switch had been yanked out years ago but never had any impact, so in going through the birds nest I just pulled the wires and bypassed it.
Thanks for all your advice. I will update.
