Author Topic: CB650 cam into CB500 motor  (Read 2011 times)
Offline triple
« on: November 22, 2015, 11:01:42 PM »
Hi all, I know this will be on the forum SOMEWHERE but don't have time to search hence the need for assistance.
I have read that the CB650/4 cam is a good alternative for the stock CB500/4 cam.
My questions regarding this are as follows
Is there any model / year CB650) cam that is the preferred item ?
What year do the 650 cams run from / to
Is it worth doing the change ( i.e power gains etc ) anyone got performance no,s ??
any other things I need to take into consideration ?
thanks in advance to all that respond.
Offline DaveBarbier
Re: CB650 cam into CB500 motor
« Reply #1 on: November 23, 2015, 03:48:51 AM »
If you read through these you'll get a good understanding of what has to be done. As far as actual numbers of power gains, maybe someone can comment.
https://www.google.com/search?q=sohc4+650+cam+500&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari#q=sohc4+650+cam+500+site:forums.sohc4.net&hl=en-us&prmd=smivn
Offline mrfish2
  • I might be a
« Reply #2 on: November 23, 2015, 06:56:16 AM »
I can comment on the performance gains, but for a 550, not a 500. The 650 cam will bring out the mid-range power a little, or that's at least what my butt dyno told me. As far as horsepower I'd say it'll add maybe 2 over stock, but you'll definitely feel the difference. My 550 put 37hp to the wheel with a 650 cam and MotoGP Werks exhaust.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Restoration Fan
  • My wife will never call me
« Reply #3 on: November 23, 2015, 07:11:45 AM »
Pretty exacting measurements for a butt dyno.  Well done!  ::)
Offline mrfish2
  • I might be a
« Reply #4 on: November 23, 2015, 07:39:16 AM »
37RWHP is about dead stock for these bikes. 50BHP is stock claimed.
That's why I say it only adds maybe 2, if any at all. The 650 cams have the same amount of lift, but longer duration, correct?
1980 CB650C - Sold
Offline buffalogt750
« Reply #5 on: November 23, 2015, 07:43:43 AM »
I thought the 650 cam had .030" more lift as well as a little more duration
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline flatlander
« Reply #6 on: November 23, 2015, 12:30:36 PM »
there's a thread here with some comparison data: http://forums.sohc4.net/index.php/topic,134461.0.html
i didn't try a 650 cam myself but i'd expect that it adds a little torque for better midrange and does pretty much nothing for top-end hp.
so... it's a "good alternative" if you have one lying around and want a bit better acceleration, and don't expect any dramatic improvements.
Offline triple
« Reply #7 on: November 24, 2015, 12:37:58 AM »
Thanks to all that replied , I  was aware of the sprocket swaps and tach drive , lobe clearance etc but was not sure if it was a worthwhile proposition.
Got a lot of links which provided good reading from people who had done the change themselves.
Thanks again fellas.
Offline flatlander
« Reply #8 on: November 24, 2015, 03:08:31 AM »
there should not be any clearance problems, the 650 cam is nothing radical. but of course you should check to be safe.
