The CB rips the clutch loose at 7,000 rpm since I installed a $200 NOS Honda stock clutch - Darn it! I just got it back together last night and my 1st ride greets me with a quick sweep of the tach needle past the 10 mark....
I made use of some bad advice while I had my 836 down for the frame mods. I had installed a new Barnett clutch fiber plate and spring kit back in August when I was putting the engine back together. It worked extremely well in terms of "grab". In fact, it worked too well and caused jumping when put into 1st and I'd had a few false neutrals show-up when going through the gears. A local friend and long-time CB750 owner told me he'd drag raced his previous 750's and used only "stock Honda clutches" without ever having one slip or problems. He insisted that he hated Barnett fibers because they would swell more than the stockers and cause the "sticky" transmission problems I was having. He also insisted the stock clutches on the CB750 worked so well that a new set of stock Honda springs would be all it needed.
Well, the engagement to first is clock-work perfect, the shifting is as smooth as any bike I own. This morning I'm really happy about taking advantage of his advice and the expense of replacing a new Barnett system with less than 200 miles with the outrageously expensive Honda fibers (those 7 fibers are $18 each! and the steels are $8). I'm happy for a good 20 miles or so. I come to a stop sign, look down and the oil gauge shows a drop in pressure, so I know she's warmed-up and the oil has thinned a little - all good. I click into 1st and hammer it once rolling fully expecting it to hoist the front tire like it's done so easily for the previous 200 miles. Nope, not this time.
A bad clutch usually shows it's ugly head in the higher gears. This damn thing is so weak that it's won't handle the 836 in 1st. I loosened up on the adjuster making sure to give the cable 1/2 of slack and brought the rpm up while in 2nd so I could watch it. At 7,000 shes starts and before I can get out -she tachs over 10,000. While I am just tickled at the output, I'm not happy at all about having to replace more clutch components.
Question - I like the shifting quality and love the way my transmission behaves with the Honda fibers/steels. Will a simple swap to heavier springs solve this? I don't want to go back to the Barnetts, but 10 grand on the old tach will soon open a few windows on the frontal case areas...
Input really appreciated.
Thanks,
Gordon
