Author Topic: Cb750 Clear clutch cover  (Read 2847 times)
Offline TheCampingPost
« on: November 28, 2015, 04:51:12 PM »
So my dad brought some scrap acrylic from work and I thought it would be a good idea to make a clear clutch cover. So with a few old bits from work I started carving away. It may or may not work but hey it's fun to make. Doing some reserch This plastic melts 100 degrees hotter than the engine will get on a hot day so hopefully that won't destroy it. One worry will be the clutch actuator applying enough pressure to crack it. May be a little crappy because I'm using an old drill press and worn bits that were used on a cnc and just moving around by hand, but hell who cares if it works, it works. I'll update as I get further
I'm 17 and I have absolutely no clue what I'm doing.
1973 cb750  Project "Blackout"
"Do What You Can, With What You Have, Where You Are" – Teddy Roosevelt.
Current Projects
1973 cb750
1984 cb700sc
My Instagram is just small current updates made day by day
https://instagram.com/projectblackoutcb750/
