Author Topic: CB550 camshaft - reface or replace?  (Read 906 times)
Offline separatist
« on: November 29, 2015, 09:04:07 AM »
I have a 74 CB550. My camshaft has moderate pitting on one face and more severe pitting on another. My question: reface (and if so by whom) or replace (and if so with what)? I wouldn't be unhappy to get a little more performance but honestly a horse or two won't make a difference in my life: I could make that up by just improving my riding skills. I can't find any new stock cams - maybe I'm not looking in the right place. I have no experience with dynoman or other performance cams.
I live in SoCal. Sorry for the newbie questions.
Re: CB550 camshaft - reface or replace?
« Reply #1 on: November 29, 2015, 09:25:35 AM »
I just got rid of my last 650 cam yesterday in a trade. If you can find one in good shape years 79-82, that would be your best replacement option.
Offline calj737
  • I refuse...
« Reply #2 on: November 29, 2015, 09:38:49 AM »
"Refacing" cams is called hard-welding them. And if you use a hard weld cam, you must also hard weld the rocker faces. This gets expensive quickly. But, for a performance build its almost necessary.
For your situation, CB750 gave you great advice. Find a good quality 650 cam and stuff it in and go. You also need to change the tach gear and tach gauge to a 650/750 unit as the ratios differ. Or find a good condition stock 550 used and plop it in.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=kn35srcaatcu1so9ototqpc374&/topic,60973.0.html
« Reply #3 on: November 29, 2015, 09:47:22 AM »
have you thekked the valve train..amd shaft for vear..on erly 550 vith floting valve shafts..it often vear aut the head housing..a fix is a later k3 77/78 valve cover ..so go for a used late type cover and cam..then you have all update parts
i hate all this v-w.... vords
Offline mrfish2
  • I might be a
« Reply #4 on: November 29, 2015, 10:55:34 AM »
If you decide you want another stock cam I've got one that only had about 4500 miles on it when I pulled it out of my bike.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
