Author Topic: Honda CB550F1 Queries  (Read 668 times)
Offline Rumpelkrankshaft
« on: December 01, 2015, 02:10:54 PM »
Two questions that I hope someone with more knowledge than me can answer:
1/ Will the fork legs (stanchion and slider) from a CB750K2 fit into the top and bottom yokes of a CB550F with no modification?
2/ Engine No. CB550E 11368XX-  Are Keihin 069A carbs correct fitment?
Thanks.
Offline mrfish2
  • I might be a
Re: Honda CB550F1 Queries
« Reply #1 on: December 01, 2015, 02:15:59 PM »
Thanks.
Can't comment on the 750 forks, but yes the 069A's are correct if your bike is an F model.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline calj737
  • I refuse...
« Reply #2 on: December 01, 2015, 02:58:56 PM »
The forks are 35mm between both models. The brake caliper arms may differ slightly though. The lower fitment on the F is different than the K on a 550, so be aware of that. A 750 is different still on the lowers.
Offline Scott S
« Reply #3 on: December 01, 2015, 03:24:55 PM »
 I have 750 forks on a K bike and the 550 brake stuff bolted up just fine. The 750 forks are longer, though. You can maybe try pushing them up through the triples to get stock 550 geometry.
 I think the F model brake stuff will work. Just use the 550 hanger/caliper/disc.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jonda500
« Reply #4 on: December 01, 2015, 06:01:06 PM »
+1  Yes and yes. 750 forks will bolt straight in and the mounting lugs for the brakes are identical, John
A starter clutch thread:
« Reply #5 on: December 03, 2015, 08:21:21 AM »
Thanks,people.
