After a complete 77' 750k rebuild, the clutch is not completely releasing. Adjusted with almost no slack left , the gears are still moving when the lever is fully compressed. I removed the clutch assembly and started to measure things as all parts are from china I'm sure. the friction discs measure at 3.65mm, more than Hondas range of 3.42 -3.58mm. I can not find any specs on how thick the plates should be, any one know? This thing really clunks when put in gear however once in gear, it doesn't seem to want to crawl. Any thing to add, Please do, I sure don't want to out this thing back together until I have this thing figured out.
