Author Topic: Cb550 wont start  (Read 589 times)
Offline Lochlea21
Cb550 wont start
« on: December 02, 2015, 12:50:24 PM »
Hi guys a wee problem thats doing my nut in,Ive a 550 four that was running fine ,but now wont start .it seems to spark ok and the plugs are wet .its got electronic ignition amd strted first start of the button ,had a few backfires but thats all
Offline Gene
  • Chat enuf you too can be a
Re: Cb550 wont start
« Reply #1 on: December 02, 2015, 12:54:37 PM »
You've checked for spark?  Make sure the plugs aren't fouled, and - not being a jerk - you have fuel?
*1973 CB750K3 (Bow)
Offline Lochlea21
« Reply #2 on: December 02, 2015, 01:02:31 PM »
Yea just put fresh fuel in ,battery started to go flat but still wouldnt start from the kick,
Offline Gene
« Reply #3 on: December 02, 2015, 01:14:08 PM »
If it had points I'd say it's maybe the points.  I'm not familiar w/the electronic ignition - from what little I can tell sounds like a timing issue.
Smarter people than me will be along - what year is the bike?
*1973 CB750K3 (Bow)
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: December 02, 2015, 01:21:39 PM »
You mentioned the plugs are wet, I would start off with that.  Get new plugs
CB550 K0
Offline Lochlea21
« Reply #5 on: December 02, 2015, 01:25:41 PM »
Do i need a fully charged battery to give a decent spark
« Reply #6 on: December 02, 2015, 01:33:20 PM »
no, but one certainly does help.
Offline mrbreeze
  • Not your average
« Reply #7 on: December 02, 2015, 01:41:06 PM »
Sounds like you flooded it and fouled the plugs. Did you initially try to start it without the choke on? Clean or replace plugs and try again with choke on.
MEMBER # 257
Offline Lochlea21
« Reply #8 on: December 02, 2015, 01:42:29 PM »
when I take a plug out ,stick it in cap and turn it over against the head the spark is weak ,but when i hold it against the exhaust seems to be better?
Offline Lochlea21
« Reply #9 on: December 02, 2015, 01:43:02 PM »
Do they foul plugs easily
Offline Gene
« Reply #10 on: December 02, 2015, 01:45:00 PM »
Depends on the set-up and situation.  Generally, no.
*1973 CB750K3 (Bow)
Offline mrbreeze
  • Not your average
« Reply #11 on: December 02, 2015, 01:50:26 PM »
You say the spark looks weak. Try it with a new plug. If it still looks weak you have other problems (state of charge, points, etc.). Also.....if it still looks weak....swap over to a plug wire from the other coil and do your spark test. 1-4 are on one coil......2-3 on the other.
MEMBER # 257
Offline Lochlea21
« Reply #12 on: December 02, 2015, 02:04:33 PM »
You sure that 1&4 is on one coils and 3&4 on the other cause ive seen wiring diagram where 1&2 r on one coil and 3&4 on the other ?
Offline Gene
« Reply #13 on: December 02, 2015, 02:20:08 PM »
Mr. Breeze is correct.
*1973 CB750K3 (Bow)
Offline Lochlea21
« Reply #14 on: December 02, 2015, 02:24:21 PM »
Could be the problem as i seem to to have 1&2 of one coil and 3&4 of the other ,dont know how that happened .So if your sitting on the bike what plugs do the left hand coils feed and what ones for the right ?
Offline Lochlea21
« Reply #15 on: December 02, 2015, 02:25:08 PM »
I presume this will stop it starting lol
« Reply #16 on: December 02, 2015, 02:36:52 PM »
the coil with the short wires feeds 2/3
the coil with the longer wires feeds 1/4
Offline Gene
« Reply #17 on: December 02, 2015, 03:14:29 PM »
On my hopelessly stock 550 - Left is 2-3, Right is 1-4
*1973 CB750K3 (Bow)
Offline mrbreeze
  • Not your average
« Reply #18 on: December 02, 2015, 03:21:52 PM »
I think we may have found the problem. I don't think the 2-3 wires are long enough to reach the outer cylinders (1-4) though.. But then again....the bike isn't in front of me.
MEMBER # 257
Offline jonda500
« Reply #19 on: December 03, 2015, 05:26:46 AM »
On all three of my 500/550's left is 2&3, right is 1&4.
John
A starter clutch thread:
