Author Topic: Cam identification , help needed. Cb 500/550  (Read 2442 times)
Offline Folsoe
« on: December 06, 2015, 11:39:23 AM »
Hello guys.  I just Got another cb 500 into the garage :)
It seems it has been tuned a bit, when i compare to another engine i have in the garage :
The bore is 59.5 mm, which Should be more than 550cc? ( its a 500 i bought)
The intake port in cylinderhead is 26.5 mm, and have signs of grinding in the ports  ( the other i have is  25 mm)
So now i am wondering about the cam shaft..
On the photo you Will see it is marked A and then R 9.  With a lobe height on 33.5 mm there is a Y on the opposite side of the cam.
The other cam in the bottom of photo is marked C and then R 10. With a lobe height on 34.5 mm.  There is a K on the opposite side of the cam.
Furthermore.  The other ends of the Cams do not look quite the same ..
Which is Right ? What is what ?  :) ??
« Last Edit: December 06, 2015, 11:56:59 AM by Folsoe »
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
Re: Cam identification , help needed. Cb 500/550
« Reply #1 on: December 07, 2015, 02:50:29 AM »
these R numbers mean nothing at al   casting number or watever    :-\
gerrit
Offline flatlander
« Reply #2 on: December 07, 2015, 03:01:10 AM »
to get an idea you could measure lift and duration, and compare with stock and other, known cams.
numbers for some cams used in 550s are in this thread: http://forums.sohc4.net/index.php/topic,134461.msg1511798.html#msg1511798
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3 on: December 07, 2015, 04:59:36 AM »
The Y cam marked A is a Yoshimura A grind, the milder of the two they offered, B was the Isle of Man TT cam.
BentON Racing Website
BentON Racing Facebook
Offline Folsoe
« Reply #4 on: December 07, 2015, 07:11:24 AM »
Thanks guys :)
I feel lucky with this buy  ;D
Ported head/ Big bore and yoshimura cam :)  and in great shape as Well :)
But it seems the lobe height is higher on the other cam than on the yoshimura cam ..
So Maybe also a kind of tuning cam..
How Can i measure the cams ? Only know how to find the lobe height..
And how many cc are a bore of 59.5 mm ?
Do i need to make ignition timing different on this Engine ? Or valve clearance ?
Offline CBGhia
« Reply #5 on: December 07, 2015, 07:31:25 AM »
Sounds like Yosh 562 kit for the CB500
Here is a link to piston rings on ebay
http://www.ebay.com/itm/Yoshimura-59-5mm-Piston-Rings-to-suit-Honda-NEW-/110641467774
Offline turboguzzi
« Reply #6 on: December 07, 2015, 07:59:12 AM »
lobe height will give you an initial measure if you are stock or not
should have a stock cam somewehre in the garage, will measure and let you know.
Bill, the one yoshi cam that passed through my hands had the Y stamped rather than forged into the core like in that pic....
that said, we will all happily help you, but if you can figure out engine cc based on the bore, maybe you should get some basic reading on mechanics....
the 550 was 58.5mm stock bore, so could easily be a +1mm overhaul piston set & block bolted on 500 cases, it's that easy to do :) .
if the piston is pretty flat then very likely that's the case. if it has some crown, then maybe it's some sort of hipo kit.
Offline turboguzzi
« Reply #7 on: December 07, 2015, 10:49:28 PM »
just checked: inlet lobes 35mm exhaust lobes 34.6mm
Offline Folsoe
« Reply #8 on: December 08, 2015, 03:36:50 AM »
Thanks.   Total camfusion:)
Offline bambuhiphop
« Reply #9 on: December 08, 2015, 03:37:15 PM »
The A grind is milder than the B?
« Reply #10 on: December 08, 2015, 05:09:15 PM »
Definitely is, yes.
Offline bambuhiphop
« Reply #11 on: December 08, 2015, 05:13:01 PM »
Definitely is, yes.
Huh, cool. I thought it was the other way around. Learned something new! Curious though, how "wild" is the B considered?
Offline turboguzzi
« Reply #12 on: December 09, 2015, 04:35:03 PM »
first of all, IN and EX lobes are different, so you need to measure both. but according to the numbers you already have, doesnt sound like a performance cam.
34.5 could be like the EX lobe i measured , but 33.5 sounds like you simply didnt measure at full height.
« Reply #13 on: December 09, 2015, 05:18:58 PM »
It may be a re-ground cam. Measure the total lobe height, then subtract the base circle, measured perpendicular to the lobe height, to determine lobe lift.
« Reply #14 on: December 09, 2015, 05:27:30 PM »
The race cam TT Special. It's fairly close to the Megacycle 126-20 which I use in my race engine.
Intake opens 27d BTDC, closes 57d ABDC. Intake lift 9.0mm
Exhaust opens 56d BBDC, closes 27d ATDC. Exhaust lift 8.55mm
The Street Special
intake opens 20d BTDC, closes 50d ABDC. Lift 8.25mm
exhaust opens 50d BBDC, closes 20d ATDC. lift 7.80mm
Offline bambuhiphop
« Reply #15 on: December 09, 2015, 05:49:26 PM »
The Street Special
Coolio, thanks much! I have a TT (B grind) sitting in the garage waiting to go in an engine. I look forward to seeing what it is like! Apologies for hijacking the thread.
