Hello guys. I just Got another cb 500 into the garage
It seems it has been tuned a bit, when i compare to another engine i have in the garage :
The bore is 59.5 mm, which Should be more than 550cc? ( its a 500 i bought)
The intake port in cylinderhead is 26.5 mm, and have signs of grinding in the ports ( the other i have is 25 mm)
So now i am wondering about the cam shaft..
On the photo you Will see it is marked A and then R 9. With a lobe height on 33.5 mm there is a Y on the opposite side of the cam.
The other cam in the bottom of photo is marked C and then R 10. With a lobe height on 34.5 mm. There is a K on the opposite side of the cam.
Furthermore. The other ends of the Cams do not look quite the same ..
Which is Right ? What is what ?
