That poor #1 cylinder, I'm guessing it doesn't get much fuel.
A lot of "+1" comments, so I take it someone can explain to us dumbheads why this would be the case.
Apart from the exhaust the engine seems to run quite silky.
BTW, that ram-air setup is an ideal flycatcher.
My personal opinion (initial startup and throttle pump aside), is that #1 would get the same air/fuel ratio as the other three cylinders.
My vacuum guages have two much longer tubes that screw into the two inner cylinder manifolds but this doesn't mean they get a lower vacuum reading than the short ones - I have checked this!
I agree that single carb looks too small for that purpose (unless it came off a 1000cc twin or something!)
John
