Author Topic: 1978 550 tank on a 1975 550k?  (Read 1423 times)
Offline 0Dogg
« on: December 08, 2015, 10:28:02 AM »
Will this be a direct bolt-on or will I have issues trying this?
    • http://forums.sohc4.net/index.php?PHPSESSID=1av11c5i9bela02heafd9ff997&/topic,60973.0.html
Re: 1978 550 tank on a 1975 550k?
« Reply #1 on: December 08, 2015, 10:31:51 AM »
it can give some problems ..thange sparkplugs..there is 1 cm less place under the tank..but it fit on..you just  have to lift the tank a bit, to get to the senter plugs
Offline Scott S
« Reply #2 on: December 08, 2015, 11:10:59 AM »
 It's less of a spark plug clearance problem and more of a "the seat gap doesn't line up correctly" problem.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline 0Dogg
« Reply #3 on: December 08, 2015, 11:11:41 AM »
Ahhh...so, in theory, if someone also sold me a seat that matches up to the '78 tank, then we might be in good shape?
« Last Edit: December 08, 2015, 11:13:34 AM by 0Dogg »
« Reply #4 on: December 09, 2015, 08:18:08 AM »
Yes, OR you could unfasten the seat from the hinges, adjust and re-mount to the hinges to accommodate for the gap.
Offline 0Dogg
« Reply #5 on: December 09, 2015, 09:11:30 AM »
Perfect.  Thanks for the insight.  I thought I might have to put these immediately onto the Classifieds forum prior to taking the '75 apart!  Now I have faith that we'll be able to figure it out!
