Author Topic: Cobra motor disassembly and rebuild  (Read 109905 times)
Offline POPS 911
Re: Cobra motor disassembly and rebuild
« Reply #300 on: April 24, 2016, 05:20:48 AM »
BILL: How thick is that stroker plate on that COBRA ???? If that motor is kick start [ total loss ] then why a stator on the end of the crank,  their must be many stators for KZ motors as I gave RICK'S a box full of stators for KZ MOTORS. Why the stock carbs or are they the bored out better than 29's carbs that GEORGE BUILDS  ???? When you run those flat slides remember what I told you about removing the rod = that bog [extra squirt ] with it on can give you a shock off the line. I got a set of clean 29's with the right stacks and a box of main jets from K&L that you can change in seconds. You 29's need a cleaning they looked rather ruff at the track when KYLE tried to get them to work with 120 main jets.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #301 on: April 24, 2016, 05:46:47 AM »
Morning POP's.  No stroker plate or motor ...yet! I'm running the RS34'S. Yes I remember about the acc. rod,  thanks.  Yes, the 29's  they came off a shelf after sitting....not good! I got some shorter stacks, some 22.5 pilots and more mains. They'll be ready. On the rotor, you got to have something hold the starter clutch. No charging system on mine, it's total loss.
BentON Racing Website
BentON Racing Facebook
Offline cbr954
« Reply #302 on: April 24, 2016, 06:33:30 AM »
I cut off and turned down rotor leaving only what I needed for the starter gear clutch.   Running these on two 72mm  12.5:1 motors and having no problem with the stock starters.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline BPellerine
« Reply #303 on: April 24, 2016, 03:55:24 PM »
your engine sounds great bill,good luck next time out!billp
1978 CB 750K ard and webers
another anfob
    • BentON Racing
« Reply #304 on: April 24, 2016, 04:09:46 PM »
That's what I'm looking for! K, Bill
Offline dragracer
  • CB750F Dragbike
« Reply #305 on: April 24, 2016, 08:11:59 PM »
Thanks all. The 24 volts took its toll on the eBay 1100F starter motor!  After working some 10-15 times, it all of sudden went click. Turned out motor was still getting power, just wouldn't spin. So I thought why beat the hell out of a starter system if not nessecary. So I went 12v. Seems to work just fine, my leg loves it! Dyno next! Calling in the am for next week appointment!  Yippee Kai Yeah,   Bill
So am I to understand that you used the same starter, but just used 12vilts, it one battery?? It did you put another starter on the bike with 12 volt wiring only??
    • BentON Racing
« Reply #306 on: April 24, 2016, 09:59:20 PM »
Used a standard CB750 SOHC starter, 12v standard wiring,  works great! A riddle for you.....off/on/on works a hell of a lot better than off/off/off! SMH, speechless! Bill
Offline POPS 911
« Reply #307 on: April 25, 2016, 02:39:11 AM »
It's a drag bike= starter and stator weight on end of crank, use that leg to kick start, must have gave RICK'S a box full of KZ starters too !!!! KZ folks kick start or use a start cart for a PRO-BIKE. Most 2 cycle. SEL bikes were kick started then they pull off the foot crank and run 8.20's.
I thought you said golden rods on your stroker crank ? Do you have the that fixture hold down plate for boring a 1062 block, my son in law made many for the 1000 KZ guys to get the true holes.
    • BentON Racing
« Reply #308 on: April 25, 2016, 04:21:21 AM »
Yes to Golden Rods std length were on it when I got it. No fixture here, but my boring usally handled by Rick Stetson through Mike Rieck. I'm sure I can kick it,  but we (me and my leg) like the button!  Lol. Nothings set in stone yet, still gotta fine tune and go to dyno this week hopefully, thanks for the input, Bill
Offline dragracer
  • CB750F Dragbike
« Reply #309 on: April 25, 2016, 09:34:13 AM »
Bill,
What's your best guess on the horsepower of this engine on the "crack fuel" based on what you got from the smaller engine?? I think you were over 100hp before??
    • BentON Racing
« Reply #310 on: April 25, 2016, 04:52:08 PM »
Frank, good question,  yes we were at 101.24 with the 915cc little rocket!  And it's about to be ready again, slightly modified version. But let's compare the two, I'll give you what I think/ hope for, anyone else feel free to chime in.
915cc                           1062cc
Crank, balanced,         Crank,  balanced, APE and lightened by
A little weight off it.     RC or someone good
Rods Falicon.                Rods Carrillo's
Primary chains OEM.   Primary chains Germany /Thomas from Rickey Racer
Cam chain RC.               Cam chain CycleX Cryo (love it!)
Cam chain tensioner     Cam chain tensioner
OEM.                                 Yoshimura replica on ebay (kmb69 assembler)
Pistons 915cc CycleX.   Pistons 1062 73mm RC Engineering
Wiseco kit ltwt. 10.5 to 1 Tapered lightweight pins 12.5 to 1
Tapered pins w/clips.      w/buttons
 Cylinder head Stage IV   Cylinder head RC ported 33.5 stainless 7mm stems
Mike Rieck 34mm intakes
5 or 5.5mm stems etc
Cam RC327.                         Cam RC327
Carbs George Schuld.        Carbs RS34'S
Bored out stockers.             Flat slides
Ignition DynaS 3ohm.          DynaS 3 ohm.
Clutch Barnett x plate.        Clutch RC x plate,copper coated steels
Pipe 4-1 Sidewinder.            Pipe 4-1 Sidewinder
Fuel VP MR12.                      Fuel  VP MR12.
H/P 101.24.                           H/P  ???.??
OK , my guess is 101.24 plus 8.76 for bore size, 4 for compression, 2 for carbs, 2 for me Lol, equals 118.xx rwhp!
Might be lucky to hit 110, but I do think more than that! What's your number?  Bill
« Reply #311 on: April 25, 2016, 07:04:28 PM »
Bill, I think 118 is reasonable. Only unknown I see is the head. 150cc and 34's should make a difference. The 12.5:1 may make the most difference. What is the weight difference between the Falicons and the Carrillos? Brian will get you there.
Offline dragracer
  • CB750F Dragbike
« Reply #312 on: April 25, 2016, 07:40:22 PM »
If it was a Kaw give a guess. I've no clue on the horsepower of the Honda engines. If you get 118, that's a great power to weight ratio. The track dyno should give you some low ET's. I assume you'll be testing at Commerce this weekend?
    • BentON Racing
« Reply #313 on: April 26, 2016, 05:04:51 AM »
Calling Brian at Livengood's this morning,  I'm going to dyno first,  then Commerce asap, Bill   ;D
Offline gschuld
« Reply #314 on: April 26, 2016, 08:33:08 AM »
I look forward to the results of the dyno visit.  I'm curious to see whether the vintage RC ported 33.5/28 head will effectively keep up with your engine's airflow needs(compared to a more contemporary major porting job or a heavily ported F head).  That's a big motor with big compression.  Good luck... ;)
My vintage stuff has a LOT in common with your vintage stuff, so I am interested for sure.
George
    • BentON Racing
« Reply #315 on: April 28, 2016, 06:46:06 PM »
Booked dyno today.  12th or 13th,  yeah, Bill
Offline dragracer
  • CB750F Dragbike
« Reply #316 on: April 28, 2016, 07:46:53 PM »
Going to the dyno Saturday -- 660' , yeah.
    • BentON Racing
« Reply #317 on: April 28, 2016, 08:18:31 PM »
LMAO, about what I expected, lol! You go Frank! K. I have a plan....hehe! You got mo work! Coming your way! Bill
Offline dragracer
  • CB750F Dragbike
« Reply #318 on: April 29, 2016, 09:31:31 AM »
Well, my butt dyno has been serving me well for 20 years now on the old Honda. The only drawback is my air fuel ratio meter- seems to emit an awful smell at times. Lol
    • BentON Racing
« Reply #319 on: April 29, 2016, 12:09:43 PM »
Yep,  a stuck throttle on a butt dyno can be messy! LMAO
Offline gschuld
« Reply #320 on: April 29, 2016, 01:05:04 PM »
 ::)      ;D
    • BentON Racing
« Reply #321 on: April 29, 2016, 01:24:48 PM »
Oh, salt in a fresh wound!  Thanks,  LMAO,  Bill
Offline gschuld
« Reply #322 on: April 29, 2016, 01:49:30 PM »
Gotta keep you in line.... :)
George
Offline BPellerine
« Reply #323 on: April 29, 2016, 05:16:08 PM »
well it sure looks interesting!billp
another anfob
    • BentON Racing
« Reply #324 on: April 30, 2016, 03:04:30 PM »
Copper on top and bottom, both Cometic, I recommend, that base gasket is a work of art!  Show em George and thanks again for the overnighter and Saturday delivery! Bill
