Author Topic: 1983 vf750 sabre front end on cb750 1975  (Read 534 times)
Offline kingjess25
« on: December 29, 2015, 06:11:43 AM »
Hi guys, I found a vf750 front end for cheap which comes with dual brakes, triple trees, tire, and forks. Was wondering if anybody knows if the tripple tree or forks from a vf750 is the same size as the cb750.
Thanks!
Sent from my SM-N910T using Tapatalk
Offline Roach Carver
Re: 1983 vf750 sabre front end on cb750 1975
« Reply #1 on: December 29, 2015, 07:13:54 AM »
I have done one very similar  this. I pressed out the tube in the trees on both and used the cb tube in the Vfr triples.
« Last Edit: December 29, 2015, 07:15:39 AM by Roach Carver »
Offline kingjess25
« Reply #2 on: December 29, 2015, 09:48:36 AM »
Let me make sure I got this right, lol. You used the neck from the cb for the vf tripples that holds the fork tubes?
How did you press the vf tripples out of the neck? Up to this point I thought the whole tripple three with the neck was just one piece.  Had no idea you can separate it.
« Reply #3 on: December 29, 2015, 10:13:43 AM »
Umm look at your stock bottom triple tree, the weld around it is really easy to see..
« Reply #4 on: December 30, 2015, 04:06:11 AM »
It's going to be easiest to grimd that weld flat and then press it out. The vf stem is too long I am pretty sure?
Offline kingjess25
« Reply #5 on: December 30, 2015, 06:36:19 AM »
Yeah, it is super long. Lol
Offline kingjess25
« Reply #6 on: December 30, 2015, 06:43:20 AM »
Yeah, i dry fitted it. I will swap the stem from the cb750 to the vf top and bottom clamps
