Hi everyone, I wonder if I could avail myself of your collective wisdom for a probable diagnosis of a problem I'm having...
First some info about the bike:
It's a 1977 CB550, but the motor is from a 1976 CB550K2. It has the PD46A carbs that were original to the bike (not the motor). The jetting is all stock. It has a MAC 4-into-1 exhaust, full intake manifold and stock aribox with stock filter. The ignition system is 100% new, plugs, coils, wires, wire caps, timing plates etc., and has been set with a timing light. Carbs were thoroughly rebuilt (by me) using an ultrasonic cleaner. The idle jets, main jets, and needles are OE. The rest of the carb parts are from a 4into1 rebuild kit. Subsequent checks with compressed air and carb cleaner show that all the passages are clear.
It starts easily with the choke on, but revs quite high (no tach at the moment, but I would guess it's around 2.5K). The throttle is snappy and responsive with the choke on. Very light backfires if I snap it shut.
With the choke off it will idle, but not very stable, and if you look at it funny, or even thing about touching the throttle (or idle speed adjustment) it dies right away. It's a gentle death- like hitting the kill switch.
I did a bench sync of the carbs, then tweaked it when idling with the choke on.
There is no black smoke, or "8-cycling". It does not load-up/clear-out, and the plugs are coming out clean- perhaps a tiny bit on the grey side.
My magic 8-ball sez "Too Lean", but the condition is totally insensitive to the air bleed adjustment. From full open to full closed it does not appear to have much effect.
Do I needed to move up from the size-42 idle jets?
Thanks in advance.
