Author Topic: Caliper Adjuster Bolt Size  (Read 420 times)
Offline Anghil
  • My first bike! '71 CB500
    • We're Alive
« on: December 29, 2015, 12:24:32 PM »
Kind of a 2 part question.
1) Can anybody inform me as to what size the caliper adjustment bolt is? It's part #11 is this diagram
http://www.cmsnl.com/honda-cb500-500-four-k1-1972-usa_model460/partslist/F++06.html#results
it's this part:
http://www.cmsnl.com/honda-cb500-500-four-k1-1972-usa_model460/bolt-caliper-adj_45117341700/#.VoLovZMrJE4
2) can someone recommend a better site/book with more precise parts info for 1972 cb500?
Cheers!
Always looking to learn something new.
Re: Caliper Adjuster Bolt Size
« Reply #1 on: December 29, 2015, 12:46:52 PM »
The shaft and threaded portion is 6mm. You probably know its special in that one end has a broad flat head with a slot. The other end has a screwdriver slot in it, right in the threads.
But, a std 6mm bolt could be rigged to work.
Offline Anghil
    • We're Alive
« Reply #2 on: December 29, 2015, 01:26:13 PM »
Just what I needed to know. Cheers! -
