Author Topic: Cb 750 f2 78 cafe build  (Read 17730 times)
Offline Yozzer74
    • Yozzer
Re: Cb 750 f2 78 cafe build
« Reply #25 on: January 03, 2016, 03:21:36 AM »
Thanks
Offline MessnerMoto
« Reply #26 on: January 03, 2016, 09:29:23 AM »
Rear set  brackets made bolts shortened .titanium hardware .caps made for ends of bolts to match the bolts new bracket welded on frame for break fluid pot.Engine bracket drilled
Really nice project!. Liking alu. thank and tail. What are the brackets you are using for rear set?
Offline Yozzer74
    • Yozzer
« Reply #27 on: January 03, 2016, 09:42:43 AM »
The reset  brackets are one offs that I had made . Similar to what others have done with there f2 .
Offline MessnerMoto
« Reply #28 on: January 03, 2016, 10:25:38 AM »
I see. But they look like some production parts. Really nice work.
Offline Yozzer74
    • Yozzer
« Reply #29 on: January 03, 2016, 10:28:59 AM »
Yeah the guy that made my oil tank and battery box made them .
« Reply #30 on: January 03, 2016, 10:36:59 AM »
Very nice bits! That oil tank looks like it holds MUCH more volume than the stocker.
Offline Yozzer74
    • Yozzer
« Reply #31 on: January 03, 2016, 10:38:44 AM »
Yeah it's a lot bigger I'm hoping it's going to be ok
« Reply #32 on: January 03, 2016, 10:41:40 AM »
I don't see any detrimental effect.  The increased volume and cooling surface may keep your oil temperature down.
Offline Yozzer74
    • Yozzer
« Reply #33 on: January 03, 2016, 10:44:48 AM »
Yeah that's what I was hoping .Had a sight glass made on side because .there's no dip stick and when it's on side stand needed to see were oil level is
« Reply #34 on: January 03, 2016, 10:46:32 AM »
Good idea.  I had the same installed on my oil tank/fender:
Offline Yozzer74
    • Yozzer
« Reply #35 on: January 03, 2016, 10:48:02 AM »
Cool does it work
Offline Sgt.Pinback
« Reply #36 on: January 03, 2016, 10:50:50 AM »
That will become a beauty!
Doc, I love a motorcycle!
Offline Yozzer74
    • Yozzer
« Reply #37 on: January 06, 2016, 02:12:58 PM »
Hi I'm getting ready to build my engine back up .I've read a few things about how to prevent oil leaks one of the things I'm not sure about is the 4 notch pins in between the head &barrels I've had my head skimmed but not the barrels .do I have to file them down or will it be ok with not having barrels skimmed .Cheers yozzer
Offline BPellerine
« Reply #38 on: January 06, 2016, 05:06:34 PM »
install the knock pins and install the head with no head gasket,look to see if the pins hold the head off the barrels,if so file them down,nice oil tank!billp
1978 CB 750K ard and webers
another anfob
Offline Yozzer74
    • Yozzer
« Reply #39 on: January 08, 2016, 02:41:51 AM »
So I put the knotch pins in the barrels& put the head on with no gasket .and there was a 2mm gap so filed them down flush with the barrels .now sits ok .
Offline Yozzer74
    • Yozzer
« Reply #40 on: January 08, 2016, 02:49:32 AM »
Installed my new tappit covers these are really nice things .
Offline Restoration Fan
  • My wife will never call me
« Reply #41 on: January 08, 2016, 02:50:00 AM »
Very nice work on this bike so far.  Subscribed.
Offline Yozzer74
    • Yozzer
« Reply #42 on: January 08, 2016, 02:51:41 AM »
Thanks Ron
« Reply #43 on: January 08, 2016, 02:13:49 PM »
Justins work is first rate, and he's a pleasure to deal with.... ;)
Offline Yozzer74
    • Yozzer
« Reply #44 on: January 09, 2016, 08:17:28 AM »
Hi will this sealer be ok for the rubber pucks on the head
Offline BPellerine
« Reply #45 on: January 09, 2016, 02:59:37 PM »
hondaman recommends permatex non hardening sealant for the pucks,think it is blue.bill
another anfob
Offline Yozzer74
    • Yozzer
« Reply #46 on: January 14, 2016, 12:47:26 PM »
Hi can anyone tell me which way the piston rings go on .and are the 2 rings a different size to each other cheers yozzer
Offline Yozzer74
    • Yozzer
« Reply #47 on: January 17, 2016, 10:35:21 AM »
Bit more done on engine rings fitted& head & barrels back on
Offline Yozzer74
    • Yozzer
« Reply #48 on: January 17, 2016, 10:40:51 AM »
Few pictures of parts on frame now there powder coated
Offline MessnerMoto
« Reply #49 on: January 17, 2016, 11:56:57 AM »
Really nice work. I think I will make something similar to your rears holders. I already measured some things needed to design rears holders. By my measurements thickens of standard f2 holders at bolts holes is 24mm?
